free RPO and VIN decode - General Forum
Thursday, November 24, 2011 9:04 AM
Since Compnine went down. I am offering to give anyone their RPO codes and will even decode the VIN if you want. I can also give you the exact day of manufacturing. (I know it's on your car) This is for GM cars ONLY.
Just PM me your vin number and I can do the rest.
Re: free RPO and VIN decode
Thursday, November 24, 2011 8:58 PM
I might need this done, I never got to printing mine off before compnine went down. How hard is it to get new RPO & Manufacture stickers? My car had them removed for some reason that is beyond me...
Friday, November 25, 2011 7:50 AM
If you are referring to the sticker under the spare tire cover... then no... can't get another one. I checked. You could always make one with the RPO codes I can send ya. PM me your vin if ya need my services.
Friday, November 25, 2011 9:10 AM
i should get you to do this for my vert
Friday, November 25, 2011 9:11 AM
pm me your vin then.
Friday, November 25, 2011 9:18 AM
gotta go get it in a bit, gotta snowblow the fron of the garage out first lol
Friday, November 25, 2011 12:55 PM
I'll PM ya my vin in a bit when I remember to write it down
Friday, November 25, 2011 5:35 PM
lol, alright.
Saturday, November 26, 2011 3:41 PM
Example:
My first Z24... R.I.P.
VIN: 1G1JF12D0S7218340
VIN Decode
1:U.S. BUILT
G:GENERAL MOTORS
1:CHEVROLET
JF:CAVALIER Z24, LS & CONV
1:TWO-DOOR COUPE (27,37,47,57,97)
1:THREE-DOOR COUPE (27)
2:ACTIVE (MANUAL) BELTS W/DRIVER & PASSENGER INFLATABLE RESTRAINT SYSTEM
D:ENG OPT - LD2 DISP - 2.3L CYL - L4 FUEL SYS - MFI DIV - 1,2,3,4 PROD IN - U.S.
0:CHECK DIGIT
S:1995 MODEL YEAR
7:FUJISAWA JAPAN
7:LORDSTOWN OH
218340: PRODUCTION SEQUENCE
RPO Codes
14C = TRIM COMBINATION CLOTH, GRAY (14C)
14I = INTERIOR TRIM LT GRAY (14I)
1AY
1SR = OPTION PACKAGE #15 OPTION PACKAGE #15 (1SR)
43U = EXTERIOR COLOR,PRIMARY (43U)
6BN = COMPONENT FRT LH COMPUTER SEL SUSP (6BN) SUSP(6BN)
7BN = COMPONENT FRT RH COMPUTER SEL SUSP (7BN) SUSP(7BN)
8DS = COMPONENT RR LH COMPUTER SEL SUSP (8DS) SUSP(8DS)
9DS = COMPONENT RR LH COMPUTER SEL SUSP (9DS) SUSP(9DS)
A31 = WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
AK5 = RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5)
AR9 = SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
AU3 = LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
C49 = DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49)
C60 = AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
CD4 = WIPER SYSTEM,WINDSHIELD,PULSE PULSE WPR(CD4)
DG7 = MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7)
DL5 = DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5)
FE2 = SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
FE9 = FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
FX2 = AXLE,FRONT,3.91 RATIO 3.91R(FX2)
IPC = TRIM,INTERIOR DESIGN (IPC)
JM4 = BRAKE SYSTEM,POWER FRONT DISC,REAR DRUM,ANTI-LOCK(CAST IRON) ANTILOCK DISC/DRUM BRK(JM4)
K34 = CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K62 = GENERATOR 105 AMP, DUAL INTERNAL FAN DUAL FAN 105 AMP GEN(K62)
LD2 = ENGINE,2.3L(2.3D),L4(DUAL OVERHEAD CAM) 2.3D(LD2)
LOD = PLANT CODE - LORDSTOWN, OH, BOC PLANT CODE - LORDSTOWN, OH, BOC LORDSTOWN,OH PLANT CODE(LOD)
MN4 = TRANSMISSION AUTO 4 SPD, 4T40-E 4-SPD A/TRANS(MN4)
MX0 = TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS(MX0)
N40 = STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40)
NF2 = EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
NK5 = STEERING WHEEL(STANDARD) STD WHL(NK5)
PG0 = WHEEL,16X6,STYLED(ALUMINUM) STYLED AL WHL(PG0)
QLG = TIRE ALL - P205/55R16/N BL R/PE ST TL AL3 TIRE(QLG)
R8T
UH8 = CLUSTER-COOL TEMP, TACH, TRIP ODOM GA(UH8)
UM6 = RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6)
US6 = ANTENNA,FIXED(PAINTED) FIXED PAINTED ANT(US6)
UX7 = SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL EXTENDED RANGE PACKAGE SHELF 4 SPKR SYS(UX7)
V73 = VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
VK3 = LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VL7 = BUMPER STANDARD IMPACT, 5 MPH, FRONT AND REAR, NEW YORK 5 MPH FRT & RR BMPR IMPACT STANDARD-NEW YORK(VL7)
VCVS Codes
10 Engine Assembly BCT TN5
35 Steering column - SIR System Only BCT FWJ
50 Instrument Cluster BC MAW
61 Transmission BCT 5WLR
65 Rear Axle Assembly BCT JNY
66 Right Front Hub Assembly BCT RW
67 Left Front Hub Assembly BCT RW
86 Powertrain/Vehicle Control Module (PCM/VCM) BCT BKZT
AB Module Assembly - Steering Wheel Inflator BCT 7103
AC Sensor Assembly - Passenger Compartment PNT 1989
AD Sensor Assembly - Forward PNT 1979
AL Module Assembly - Passenger Inflator BCT 0245
AN Sensor - Assembly - Dual Pole Arming PNT 7749
CB Sequence Numbers (Flex) Body Assembly Area T 1ZZ
CP Sequence Numbers (Flex) General Assembly Area T 1WW
Wednesday, November 30, 2011 10:06 AM
I'll PM when I remember. Just to check against what I have already.
Wednesday, November 30, 2011 3:34 PM
no problem. Whenever, lol.
Wednesday, December 07, 2011 2:47 AM
PMed
NCR-SCCA Street Touring Compact #18 Cones killed: 26
Wednesday, December 07, 2011 6:00 PM
Chelotus Racer wrote:
PMed
you got mail, lol
Wednesday, December 14, 2011 5:39 AM
1G1JC1248X7308903
Looking at this for the brother for a daily. I think it might be a flood car or something.....just wondering on options.
Tuesday, December 20, 2011 11:45 PM
Sorry for the late replies to some people. Sorry Mike, Brent, and Mike. You all have a PM with your RPO information.
Monday, January 02, 2012 12:20 PM
I have two more vins with your name on them!
Tuesday, January 03, 2012 7:24 PM
PM me them and I shall decode them.
Tuesday, January 03, 2012 8:05 PM
PMed
Tuesday, January 03, 2012 11:16 PM
colt45 wrote:
PMed
you have a message with your RPO information
Edited 1 time(s). Last edited Tuesday, January 03, 2012 11:22 PM
Wednesday, January 04, 2012 3:31 AM
Probably will send at least one tonight.
Tuesday, January 10, 2012 10:09 PM
YOU HAZ PM
Wednesday, January 11, 2012 5:28 AM
Thanks man!
Monday, January 16, 2012 1:36 AM
i shall pm you
2010 Lonestar Bash 2nd place J-Body Street Class
2011 texas heatwave 2nd place american compact street class
Wednesday, January 18, 2012 1:20 AM
Trey Reed wrote:
i shall pm you
I shall respond...
Edited 3 time(s). Last edited Wednesday, January 18, 2012 1:23 AM
Friday, January 20, 2012 10:30 AM
pm sent
