going to look at another supercharged cavy - General Forum
Tuesday, July 24, 2012 5:41 PM
what should i look for? the owner says the transmission is messed up but it runs fine.. is there just anything i should look for to know if it was installed correctly?
Re: going to look at another supercharged cavy
Tuesday, July 24, 2012 6:13 PM
also how do i tell what pulley it has on it? will there be marks?
Tuesday, July 24, 2012 6:34 PM
Stock is black and made of steel. Aftermarket pullies will usually marked with the size ad you can tell if its aftermarket if it has a 4 or 5 bolt hub on it. Aftermarket pullies are bolted on a hub and the stock one is pressed on the charger shaft.
The trans isnt that bad if you have basic tools and know how. I picked myself a coule spares at a local pick it yard for like $90 each.
Tuesday, July 24, 2012 6:37 PM
i believe it has a 2.9 on it, also the injectors are green top fords and has stage 2 comp cams. the injectors should not be maxed out right?
