Saab water lines - General Forum
Saab water lines
Friday, October 18, 2013 5:03 PM
Can anyone post a picture of where the saab water lines run on an ecotec? Even better in a jbody. I want to use the factory turbo lines if possible.
Thank you.
Re: Saab water lines
Friday, October 18, 2013 7:20 PM
The one line goes to the main 1.5" coolant line by the valve cover.
The other line goes to a heater core line.
Jason Norwood makes some nice fittings for this. Basically you cut the hoses and install this fitting so that you can tap into the lines for the turbo.
Friday, October 18, 2013 7:26 PM
I know about that, but the 1 factory saab coolan line has 2 bango bolts. That is what I am trying to figure out.
Friday, October 18, 2013 10:00 PM
You need the saab thermostat housing for the banjo bolt line to work, if I'm not mistaken, same on the LNF setup too
Friday, October 18, 2013 10:42 PM
Is it bolt on? I will grab one since I need a thermostat retainer.
