2002 Sunfire ABS, Traction Control & Service Light Comes on intermittently. - General Forum
Tuesday, November 10, 2015 12:21 AM
I have a 2002 Pontiac Sunfire that has an ABS, Traction Control and Service light that keeps appearing after driving for a few minutes. Usually comes on after hitting a crack or pothole in the road. The brake pedal pulsates multiple times and then all three lights appear and I lose my ABS and Traction Control. Anyone know what could be causing this? Maybe loose or shorted wiring? Thanks.
Re: 2002 Sunfire ABS, Traction Control & Service Light Comes on intermittently.
Tuesday, November 10, 2015 4:53 AM
It is the ground, or one of the main grounds that go from engine / trans. Also, you probably have a short in one of your ABS wires...and/or a sensor is going bad.
Either case can cause this.
Thursday, November 26, 2015 3:13 PM
Could it be something with one of the wheel speed sensors?
Thursday, November 26, 2015 7:40 PM
I'm willing to bet it's the wheel speed sensor. Had one go bad after bumping into it while changing sway bar bushings. I'd be driving, hit a bump and the same symptoms occurred. Hard part is figuring out which one. I knew because I bumped the one. Stupidly easy to fix though, 60$ wiring harness. Cut the wiring from the old and splice the new. Maybe an hour, if that.
