PARTING REAPER.... possibly - Page 2 - General Forum
Re: PARTING REAPER.... possibly
Thursday, January 28, 2016 12:57 PM
DFF- Breaking The Boundary wrote:Engine-
Stock 96 block- bored .060-$3000-- Motor includes all parts from shortblock
All Clevite 77 bearings
Hot tanked block
Crower I beam rods
Cp custom flat top pistons 10.1 compression
Swain tech coated pistons
Deleted balance shafts
Deleted factory oil pump system
7qt Dry sump oil system
Barnes 3 stage pump-$1350 ( this is the complete system, pump, tank, gear lines etc)
Lightweight Factory balancer pulley
Rotating assembly fully balanced
Ported and polished head
1mm Oversized valves
Titanium Retainers
2.3 QUAD 4 HO cam shafts
2.3 QUAD 4 HO cam shaft housings
Cometic MLS head gasket .035 thick
ARP Rod bolts, main bolts and head bolts
Custom made Oil pan with heatsink
Custom made Tubular Header-$450 ( called by BLWn LD9)--------------------------------------SOLD
Custom made LOG intake manifold with velocity stacks-$500
TTR upper motor mounts-$75
Poly lower Mounts and Transmission mount-$50
80MM throttle Body-$100
Phenolic head Spacer-$20
T3/T4 turbonetics turbo-$300
3" Dump all the way to back-$250
Aluminum exhaust from firewall back-$200
Electric WaterPump-$300 with lines and block off plate for engine
Becool 3" core aluminum radiator-$250
160* Thermostat
Fuel LAB AFPR-$80
Tial Waste gate-$125
Tial BOV-$125
Intercooler- $300----Hold for Trey Reed
Suspension
Custom made KONI Race Coilovers with 700# in front and 800# in back Hyperco Springs-$1000----SOLD
Custom made Tubular control arms-$350----SOLD
Modified rear torsion beam
BBS 2 piece wheels with BFG KDW Tires 235/45/17-$700
Front Addco sway bar with poly bushings-$80----SOLD
Wilwood 4 Piston brakes front-$1000 (called by BLWN LD9)
Disc conversion for Rear brakes--$300
N Body Knuckle upgrade in front
Camber plates front---SOLD
Spherical rear Mounts in rear---SOLD
Custom made Subframe brace-$75----SOLD
Custom made K brace-$200----SOLD
Custom made rear Triangulated rear brace----SOLD
Bump Steer Kit Custom made-$50----SOLD
Custom made Overflow tank-$40----SOLD
Transmission
35k mile 01 Getrag transmission fully torn apart and checked over-$2500 (Comes with Quaife LSD)
Spec stage 4 clutch-$200
Rk sport Aluminum Flywheel-$200
ARP Flywheel bolts--$10
Custom fit LD9 jackshaft. TO F23 TRANS---$300
Fuel
10 gallon fuel cell
2 Walbro 255HP Out of tank fuel pumps
Fully walked AN fittings and hose front to back
42# Green tops injectors
Custom built fuel rail-$400 with lines
Aeromotive Adjustable FPR
Other
Custom built roll cage 8pt
AEM Boost controller- $180
Autometer EGT- $100
AutoMeter boost gauge-$35
Autometer Water temp-$35
Innovate Wideband-$150
AutoMeter Oil Temp-$30
AutoMeter Oil PSI- $30
Sparco seats- $750
Scrotch 3" harnesses-$250
Emergency Battery cut off switch
Front and rear Tow Hooks- $15
TOYO TAILS- $150----Hold for Ecoswapped-----SOLD
projector headlights--$50
Hp tuners computer-$50
Engine harness with computer- $150
Intercooler piping- $150
Couplers-$30
http://www.overkillengineeringmotorsports.com/
Thursday, January 28, 2016 3:55 PM
any chance of parting out the import fighter kit?
Friday, January 29, 2016 7:15 AM
The body kit? Yes I would, both bumpers, hood and side skirts. Send me a offer.
Mark
Friday, January 29, 2016 7:18 AM
Hot tanked block
Crower I beam rods
Titanium Retainers
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125
Suspension
Transmission
Fuel
10 gallon fuel cell
Other
Autometer ULTRA LITE DIGITAL 6545 EGT- $100
AutoMeter ULTRA LITE PRO COMP boost gauge 4301-$35
Autometer ULTRA LITE DIGITAL 6537Water temp-$
AutoMeter ULTRA LITE PRO COMP 4347 Oil Temp-$30
AutoMeter Oil PSI- $30-----SOLD
Sparco seats- $750
Couplers-$30
Friday, January 29, 2016 12:43 PM
Hot tanked block
Crower I beam rods
Titanium Retainers
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125
Suspension
Transmission
Fuel
10 gallon fuel cell
Other
Autometer ULTRA LITE DIGITAL 6545 EGT- $125
AutoMeter ULTRA LITE PRO COMP boost gauge 4301-$40
Autometer ULTRA LITE DIGITAL 6537Water temp-$80
AutoMeter ULTRA LITE PRO COMP 4347 Oil Temp-$40
Sparco seats- $750
Couplers-$30
Saturday, January 30, 2016 8:28 AM
Would you take $150 for the hood and trunk?
Monday, February 01, 2016 6:23 AM
Engine-
Hot tanked block
Crower I beam rods
Titanium Retainers
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125
Suspension
N Body Knuckle upgrade in front---HOLD FOR ROB DOTTER $350
Transmission
Fuel
10 gallon fuel cell
Other
AEM Boost controller- $180-----SOLD
Sparco seats- $750-------SOLD
Couplers-$30
Hood and Trunk-----HOLD FOR JOHN HIGGENS---$300
Imprort Fighter Kit----$500
Monday, February 01, 2016 12:50 PM
Hot tanked block
Crower I beam rods
Titanium Retainers
Electric WaterPump-$300 with lines and block off plate for engine-----SOLD
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125
Suspension
Modified rear torsion beam WITH POLY BUSHINGS ------$200
N Body Knuckle upgrade in front---HOLD FOR ROB DOTTER $350 SOLD
Transmission
Fuel
10 gallon fuel cell-----HOLD FOR SPENCER
Other
Couplers-$30
Tuesday, February 02, 2016 4:37 AM
Picture update. Disassembly has started. Should see parts shipping this week. For those of you that have not paid shipping I will get you the shipping price as soon as its boxed up.
Mark
Tuesday, February 02, 2016 5:03 AM
Hot tanked block
Crower I beam rods
Titanium Retainers
80MM throttle Body-$150
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125
Suspension
N Body Knuckle upgrade in front- $350
Transmission
Fuel
Other
TOYO TAILS- $150----Hold for Ecoswapped-----SOLD SHIPPED
Couplers-$30
Wednesday, February 03, 2016 7:18 AM
Hot tanked block
Crower I beam rods
Lightweight Factory balanceD pulley- MD ENFORCER---$100
Titanium Retainers
Electric WaterPump-$300---SOLD
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125
Intercooler HAHN http://www.turbosystem.com/hahn/parts/intercool.htm- $300
Suspension
Wilwood 4 Piston brakes front-$1000---SOLD
N Body Knuckle upgrade in front- $350---SOLD
Camber plates front---SOLD----SHIPPED
Spherical rear Mounts in rear---SOLD---SHIPPED
Custom made Subframe brace-$75----SOLD---SHIPPED
Custom made K brace-$200----SOLD----SHIPPED
Custom made rear Triangulated rear brace----SOLD----SHIPPED
Transmission
Custom fit LD9 jack shaft. TO F23 TRANS---$300
Fuel
Other
AutoMeter Oil PSI- $30-----SOLD----SHIPPED
Sparco seats- $750-------SOLD---SHIPPED
Couplers-$30
Imprort Fighter Kit----$500---HOLD FOR AUSTIN
Wednesday, February 03, 2016 8:03 AM
Hot tanked block
Crower I beam rods
Titanium Retainers
160* Thermostat
Fuel LAB AFPR-$80
Tial Waste gate-$125---HOLD FOR JASON
Tial BOV-$125
Suspension
Transmission
Fuel
Other
TOYO TAILS- $150----Hold for Ecoswapped-----SOLD--- SHIPPED
Couplers-$30
Thursday, February 04, 2016 6:10 AM
Engine-
Hot tanked block
Crower I beam rods
Titanium Retainers
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125
Suspension
Transmission
35k mile 01 Getrag transmission fully torn apart and checked over-$2000 (Comes with Quaife LSD)-----PRICE CUT
Fuel
Other
Couplers-$30
Import Fighter Kit----$500---HOLD FOR AUSTIN----SOLD
Thursday, February 04, 2016 8:19 AM
Engine-
Stock 96 block- bored .060-$2500-- Motor includes all parts from shortblock----------PRICE CUT
Hot tanked block
Crower I beam rods
Barnes 3 stage pump-$1150 ( this is the complete system, pump, tank, gear lines etc)-------PRICE CUT
Titanium Retainers
Custom made LOG intake manifold with velocity stacks-$450------PRICE CUT
T3/T4 turbonetics turbo-$250----PRICE CUT
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125
Intercooler HAHN http://www.turbosystem.com/hahn/parts/intercool.htm- $300------HOLD FOR TREY
Suspension
BBS 2 piece wheels with BFG KDW Tires 235/45/17----$700
Disc conversion for Rear brakes--$250---PRICE CUT
Transmission
Fuel
Other
Couplers-$30
Friday, February 05, 2016 6:26 AM
Engine-
Hot tanked block
Crower I beam rods
Titanium Retainers
160* Thermostat
Fuel LAB AFPR-$80
Tial Waste gate-$125------SOLD
Tial BOV-$125
Suspension
Transmission
Fuel
Other
Couplers-$30
Friday, February 05, 2016 6:28 AM
Engine-
Hot tanked block
Crower I beam rods
Titanium Retainers
160* Thermostat
Fuel LAB AFPR-$80
Tial Waste gate-$125---HOLD FOR JASON-------SOLD
Tial BOV-$125
Suspension
Transmission
Fuel
Other
Custom built roll cage 8pt-----$750
Couplers-$30
Friday, February 05, 2016 11:22 AM
Engine-
Hot tanked block
Crower I beam rods
Titanium Retainers
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125
Intercooler HAHN http://www.turbosystem.com/hahn/parts/intercool.htm- $300------HOLD FOR TREY-------SOLD
Suspension
Transmission
Fuel
Other
Front and rear Tow Hooks---------SOLD $15
Couplers-$30
Friday, February 05, 2016 2:08 PM
Engine-
Hot tanked block
Crower I beam rods
Titanium Retainers
160* Thermostat
Fuel LAB AFPR-$80
Tial BOV-$125---------SOLD
Suspension
Transmission
Fuel
Other
Couplers-$30
Saturday, February 06, 2016 1:28 PM
Hot tanked block
Crower I beam rods
Titanium Retainers
T3/T4 turbonetics turbo-$250----PRICE CUT--------SOLD
160* Thermostat
Fuel LAB AFPR-$80
Suspension
Disc conversion for Rear brakes--$250---PRICE CUT-------SOLD
Transmission
Fuel
Other
AutoMeter ULTRA LITE PRO COMP boost gauge 4301-$40-------SOLD
Hp tuners computer-$50------SOLD
Engine harness with computer- $150-------SOLD
Couplers-$30
Sunday, February 07, 2016 5:52 PM
Engine-
Hot tanked block
Crower I beam rods
Titanium Retainers
160* Thermostat
Fuel LAB AFPR-$80
Suspension
BBS 2 piece wheels with BFG KDW Tires 235/45/17----$700-------SOLD
Transmission
Fuel
Other
Couplers-$30
Monday, February 08, 2016 6:04 AM
Engine-
Hot tanked block
Crower I beam rods
Titanium Retainers
Aluminum exhaust from firewall back-$100
160* Thermostat
Fuel LAB AFPR-$80
Suspension
Transmission
Fuel
Other
Couplers-$30
Monday, February 08, 2016 7:58 AM
Tuesday, February 09, 2016 6:46 AM
Hot tanked block
Crower I beam rods
Titanium Retainers
80MM throttle Body-$150----------SOLD
160* Thermostat
Fuel LAB AFPR-$80
Suspension
Transmission
Fuel
Other
Autometer ULTRA LITE DIGITAL 6537Water temp-$80-----------SOLD
Couplers-$30
Tuesday, February 09, 2016 11:54 AM
coolant tank is gone, yes?
Wednesday, February 10, 2016 6:33 AM
