Weird handling car - General Forum
Weird handling car
Monday, March 06, 2017 5:00 AM
Does anybody have any problems with their car sliding in wet weather or a swaying on rough roads? Got to try to figure this thing out so it's safe for my wife to drive
Re: Weird handling car
Monday, March 06, 2017 9:45 PM
Are u sure its actually sliding? I had a bad shock in the rear that would pull the car around
ReD RaiN
Tuesday, March 07, 2017 4:19 AM
I actually found the problem this morning at work. I was looking at a co workers car and comparing the way the rear wheels set, turns out it looks like the rear axle may be bent causing an alignment issue. The car had been wrecked when we bought it and had mismatched wheels when we checked it out. Now that it has 4 matching wheels and I knew what to look for the driver's side rear wheel leans in slightly but the passenger leans in noticeably more.
Tuesday, March 21, 2017 6:47 PM
Have you fixed the alignment issue already? Sounds a good hit from the accident.
Tuesday, June 27, 2017 5:13 PM
That's good then. So, everything's working fine now with your car?
Thursday, June 29, 2017 9:17 AM
Always check the basics first. Correct tire sizes, correct air pressure, no loose, bent, or broken suspension parts or bearings.
Currently 6th quickest Ecotec on the .org -12.453 @ 116.45 MPH!!!
