2.4 replaced crank, no start - General Forum
Saturday, September 23, 2017 9:02 PM
I just swung a 99+ engine in my 97 cavz24. The knock sensor and upstream o2 sensors are both different and are not plugged in at the moment. Will these 2 sensors cause the car not to run. We have tested the ignition system and the spark is present but seems very weak. I have extra ignition parts, so I've already swapped coil packs, ICM, "plug wires" and even plugs. Fuel pump is working and fuel is being delivered, just no start. I am going to install the correct o2 and knock sensors tomorrow. any other advice would be appreciated.
Re: 2.4 replaced crank, no start
Monday, September 25, 2017 4:45 AM
Run ALL electronics from the 97 engine. The 99 engine should have the same O2 sensor. If it is not a purple one wire, you have a 00-02 engine.
