yellow foam in oil? - Maintenance and Repair Forum
yellow foam in oil?
Monday, April 02, 2007 7:59 PM
pulled the dipstick to check oil levels on my moms car and its got a yellow foam build-up on the end of the dipstick. I then pulled the oil cap and it had the same build-up there.
any ideas on the cause
apparently she knew of this before and asked a mechanic about it, he said it could be the head gasket, that makes no sense to me though.
2.2 eco, auto with A/C
Re: yellow foam in oil?
Monday, April 02, 2007 8:26 PM
water in oil
Tuesday, April 03, 2007 5:37 AM
Foamy oil = blown head gasket, 9 out of 10 times. Have cooling system pressure and compression tests done to confirm.
1989 Z24 Convertible - Dust Covered
2006 tC - Dust Covered, but driven more
Tuesday, April 03, 2007 10:14 AM
ZlineDavid wrote:Foamy oil = blown head gasket, 9 out of 10 times. Have cooling system pressure and compression tests done to confirm.
X2
Tuesday, April 03, 2007 12:35 PM
foam in the oil is really not 9 times out of 10 the HG. Most 2.3 make foam even new. Humidity will do it. Nothing to worry about.
Milky oil is a bad sign but a bit of foam is no problem.
Gilles
2.3 Ho
Tuesday, April 03, 2007 2:03 PM
That yellow gunk can be caused by cold temps or short trips and the car not being able to warm up to burn it off (condensation like Mfk-223 said)
Rob
Sold 2/2/05
