 you are here: / home / forum
Saturday, November 21, 2009
Where is the PCM in the engine bay - Maintenance Forum
Discussion about general maintenance, maintenance issues, and other normal and not-so-normal j-body issues.
Go To TopSearchOptionsRulesHelp
Previous MessageNext Message
Friday, October 23, 2009 3:38 AM
K I'm at the last idea why this damn car won't start I have a buddy who's a friend of the family and he found that I a short back in two of the wires that go to my new fuel pump so he thinks its the PCM , we have checked everything from front to back in that car so I need to get to that PCM and I don't know where its at ,can some one please tell me excactly where I need to start to get it out and replace it.............................
Advertisement
Upgrade to premium membership to remove this ad.
Re: Where is the PCM in the engine bay
Friday, October 23, 2009 4:30 AM
Passenger side fender. pull the wheel well liner out (includes part that goes under the bumper cover) and its right in there. Does not really sound like the PCM to me though.
"I would totally eat a marshmallow fairy." - Pintsize
Friday, October 23, 2009 1:50 PM
Yh thats my buddy telling me that it might be bad which he is a top mechanic and he does know what he's doing so I will trust him on it and if its not that then I will move to the next thing I guess, any idea's what anyone thinks it could be???????????????
Friday, October 23, 2009 2:13 PM
Web Page
try it but just so you know we hear this all the time my buddy/dad/whoever is a class A or top notch or master mechanic. they do make mistakesi had a mechanic that i trust and i still go to and hes misdiagnosed my car a couple times it happens
Friday, October 23, 2009 7:04 PM
Yh I know it happens but at this point I'm out of ideas and no where else to turn to unless you guys have some better suggetions, I'm all ears for whatever you recommend.....
Friday, October 23, 2009 11:28 PM
Does anyone think that it maybe the ignition switch??? and the PCM?? Also my key is wore down it seems so I'm going to go to the dealer and get a new key so I can try the theft lock @!#$ but wouldnt that have thrown a code on my boys scanner or computer when he had it on there????????
Saturday, October 24, 2009 4:39 AM
If he's a top mechanic, why are you asking here? He should know where the PCM is. If there's a short at the fuel pump, it wouldn't even prime.
Your car may do 13 sec @ 103 mph, but my car does 146db @ 35 hz.
Saturday, October 24, 2009 12:46 PM
He' s not helping me get the PCM out and he gave me an idea where it was but it was at night also , I have to get this out myself on this one and also someone else send somthing about a ignition switch does that sound like it might be part of it also?? I'm asking on here cause I thought this is what this was for was finding help from other guys who knew these cars???
Saturday, October 24, 2009 12:51 PM
What exactly is your car doing?
Saturday, October 24, 2009 12:58 PM
"found that I a short back in two of the wires that go to my new fuel pump so he thinks its the PCM"
If you have a short in the wires that go back to the fuel pump how is it a bad PCM? Use your brain and think about it. if the wires that go to and from the PCM were tested through the PCM (never tried this and doubt it would actually happen) and it was shorted regardless of key position then there may be something. However I have never tried such a test for a fuel pump control circuit (especially since the PCM controls a relay that then controls the pump circuit) so I dont know what the expected outcome would be. Maybe you have a bad fuel pump, or a pinched wire, or a short to ground, or a bad relay, or...........
If you want to just listen to him without first checking all the wiring by itself then go ahead and buy a new PCM and pay to have it programed. Just dont be surprised if it does not fix the issue.
Saturday, October 24, 2009 1:59 PM
The car is cranking but just won't catch it just seems like there is no fuel going from the pump to the engine ,we tested all the fuse's and the relays, put a new pump in and still will not start . So I will check the wires and see if any are pinched and try to test the wires in between before buying a new pcm .I def need to get a ignition switch and key cause my key is wore down and the where u put the key in is a little messed up so I will try this crap first and then go from there.
Saturday, October 24, 2009 2:03 PM
Sounds like your master tech buddy needs to learn how to diagnose before throwing parts at a car.
Saturday, October 24, 2009 2:11 PM
K well besides the friend thing all aside , so what do I really need to as far as testing to see why the pump is not getting power thats all I need to know I guess, so can someone actually give me more of a straight answer insted of the run around ones.I don't care who is a master or not. I have just put in a new pump checked the relay and fuse's they all are working but the pump must not be getting power so what do I do as far asgetting the thing POWER ?? I know for a fact that the pump is not sending fuel up to the rail!!!!
Sunday, October 25, 2009 6:11 AM
Does it do the initial prime? You'll definitely hear it do its thing.
Sunday, October 25, 2009 12:31 PM
YH I dont hear anything when I turn the key, my Theft system light stays on it doesnt blink or do anything but I think that the problem is that my key is very worn out and I have to get a new key from the dealership..
