 you are here: / home / forum
Monday, November 23, 2009
Cam Cover Gasket - Maintenance Forum
Discussion about general maintenance, maintenance issues, and other normal and not-so-normal j-body issues.
Go To TopSearchOptionsRulesHelp
Previous MessageNext Message
Cam Cover Gasket
Tuesday, November 03, 2009 7:01 AM
ICQAOL IMMSN MessengerYahoo Messenger
Can some one point me in the right direction to change my cam cover gasket(s). took my car in last night to find out why i am leaking oil and they told me its the cam cover gasket, which is a 7.5 hour labor job. if i can do this myself that would save me a TON of money.
The man who smiles when things go wrong has thought of someone to blame it on. - Robert Bloch
Advertisement
Upgrade to premium membership to remove this ad.
Re: Cam Cover Gasket
Tuesday, November 03, 2009 11:23 AM
AOL IMYahoo Messenger
75. hours labour for a cam cover? i am in the wrong field.
Tuesday, November 03, 2009 1:11 PM
Web PagePhoto
REMOVAL & INSTALLATION
On the 2.3L and 2.4L engines, there is no valve cover. The enginee feature a cover over the cylinder head and camshaft housing. The cover has integrated camshaft bearing cape located on the bottom of the cover.
2.3L and 2.4L DOHC Engines
INTAKE CAMSHAFT
See Figures 1, 2, 3, 4 and 5
1.Disconnect the negative battery cable.
2.Detach the ignition coil and module assembly electrical connections.
3.Unfasten the ignition coil and module assembly-to-camshaft housing bolts, then remove the assembly by pulling it straight up.
Fig. 1: To remove the ignition coil and module assembly, remove the bolts then lift the assembly straight up-DOHC engine shown
4.Remove the power steering pump.
5.Detach the oil/air separator (crankcase ventilation system). Leave the hoses attached to the separator, disconnect from the oil fill, front cover and intake manifold, then remove as an assembly.
6.Unfasten the vacuum line from the fuel pressure regulator and fuel injector harness connector.
7.Disconnect the fuel line retaining clamp from the bracket on top of the intake cam housing.
8.Unfasten the fuel rail-to-camshaft housing retaining bolts, then remove the fuel rail from the cylinder head. Be sure to cover the injector openinge in the cylinder head, cover the injector nozzles and leave the fuel lines attached and position the fuel rail aside (on top of the master cylinder).
Fig. 2: After removing the fuel rail, cover the injector openings in the cylinder head to prevent any debris from falling in
9.Disconnect the timing chain housing at the intake camshaft housing but do not remove from the vehicle.
10.Unfasten the cam housing cover-to-housing retaining bolts and the cam housing-to-cylinder head bolts.
11.Use the reverse of the tightening procedure (in the accompanying figure) when loosening the camshaft housing-to-cylinder head bolts.
12.Push the cover off the housing by threading four of the housing-to-head retaining bolts into the tapped holes in the cover. Make sure to tighten the bolts evenly remove the cover from the vehicle.
Fig. 3: Exploded view of the cam cover and related components
13.Remove and discard the cover-to-housing seals and clean the mating surfaces.
To install:
14.Position new seals on the camshaft cover. Refer to the accompanying figure.
Fig. 4: Intake and exhaust cam housing-to-cover seal locations
15.Apply pipe sealant GM part number 1052080 or equivalent to the camshaft housing and cover retaining bolt threads. Using J 366660, install the bolts, then tighten in sequence to the specifications in the accompanying figure.
Fig. 5: Intake and exhaust camshaft bolt tightening sequence
16.Fasten the timing chain housing.
17.Uncover fuel injectors, then lubricate new injector O-ring seale with clean engine oil and install on the injectors.
18.Uncover the injector openinge in the cylinder head, then install the fuel rail onto the cylinder head. Install the fuel rail-to-cylinder head retaining bolts and tighten to 19 ft. lbs. (26 Nm).
19.Install the fuel line retaining clamp and retainer to the bracket on top of the cam housing.
20.Connect the vacuum line to the fuel pressure regulator. Attach the fuel injector harness connector.
21.Install the oil/air separator assembly. You may want to lubricate the hoses to ease installation.
22.Lubricate the inner surface of the camshaft seal with clean engine oil, then install the seal into the camshaft housing using tool J 36015, or equivalent seal installer.
23.Using tool J 36015 or equivalent pulley installer, install the power steering pump drive pulley onto the intake camshaft.
24.Install the power steering pump assembly and the drive belt. Adjust tension to specification.
25.Fasten any spark plug boot connector assembly that stuck to a spark plug back onto the ignition coil and module assembly.
26.Position the coil and module assembly over the spark plugs, then push the assembly straight down. Make sure it is properly seated.
27.Clean off any loose lubricant from the coil and module assembly-to-camshaft housing bolts. Apply pipe sealant GM part number 1052080 or equivalent, onto the bolts, then tighten the bolts to 16 ft. lbs. (22 Nm).
28.Attach the coil and module electrical connector.
29.Connect the negative battery cable, then start the engine and inspect for oil leaks.
EXHAUST CAMSHAFT
See Figures 3, 4 and 5
2.Detach the ignition coil and module electrical connection. Remove the coil and module assembly-to-camshaft housing bolts, then remove the assembly by lifting it straight up.
3.Disengage the electrical connection from the oil pressure switch.
4.For vehicles equipped with an automatic transaxle, remove the transaxle fluid level indicator tube assembly from the exhaust camshaft cover, then position it aside.
5.Disconnect, but do not remove from the vehicle, the timing chain housing at the exhaust camshaft housing.
6.Remove the exhaust camshaft cover and gasket, then discard the gasket. Clean all old gasket debris from the cover mating surfaces.
To install:
7.Position new camshaft housing-to-cover seals. No sealant is needed.
8.Apply pipe sealant GM part number 1052080 or equivalent to the threads of the camshaft housing and cover retaining bolts.
9.Position the cover onto the housing, then tighten the bolts, in sequence, to specification.
10.Tighten the timing chain housing retainers.
11.Install the transaxle fluid level indicator tube assembly to the exhaust camshaft cover.
12.Attach the oil pressure switch electrical connector.
13.Reinstall any spark plug boot connectors that may have been stuck to a spark plug, back onto the ignition coil and module assembly.
14.Position the coil and module assembly over the spark pluge then push it straight down making sure it is firmly and properly seated.
15.Clean off any lubricant on the coil and module-to-camshaft housing bolts. Apply pipe sealant GM part number 1052080 or equivalent to the bolts, then tighten them to 16 ft. lbs. (22 Nm).
16.Attach the ignition coil and module assembly electrical connector.
17.Connect the negative battery cable, then start the engine and inspect for leaks.
Feel free to paypal me $5.00 for taking the time to post this for you.
Tuesday, November 03, 2009 1:59 PM
Yahoo Messenger
7.5 hours is about right
2004 Cavalier - daily driver 75k, still got the original tires on it
Tuesday, November 03, 2009 2:03 PM
About 2-2.5 hours in a driveway with hand tools.
"I would totally eat a marshmallow fairy." - Pintsize
Tuesday, November 03, 2009 3:38 PM
Web PageAOL IMPhoto
i'd expect closer to 4+ hours based on if you've never done it before and skill level. it its fairly easy though.
do yourself a favor and pickup a haynes manual too. for the most part ecocav's instructions are good, but it wouldnt hurt to have anyway.
