How to access lifters on ld9 - Maintenance and Repair Forum
Wednesday, August 21, 2013 1:49 AM
How do you get access and remove the lifters on a ld9? Car is a 2000 z24. I am getting really tired of this annoying ticking noise and I want to see how much work is involved and any gaskets/ parts that need to be replaced in the process.
Re: How to access lifters on ld9
Wednesday, August 21, 2013 5:22 AM
Just an idea but have you changed the exhaust gasket yet?
Wednesday, August 21, 2013 7:17 AM
Time consuming and tedious.
You have to remove the timing set in the housing, remove the cam gears, then remove the cams. Then you can access the lifters to inspect.
Wednesday, August 21, 2013 8:11 AM
Philly D wrote:Just an idea but have you changed the exhaust gasket yet?
I replaced the exhaust gasket when I changed my timing chain and water pump.
My car sounds like a baseball card on a bicycle wheel.
Wednesday, August 21, 2013 8:48 AM
its pretty much everything you did to change the chain, plus remove the cam gears and housing, then you can take the towers off. pain in the butt
Wednesday, August 21, 2013 10:11 AM
Anyone have any idea why my car sounds like this? Stars around 1500-2000 and is really loud around 3000. I can make a video.
