Rattle from Right Front - Maintenance and Repair Forum
Sunday, March 30, 2014 9:23 AM
Hello All. This is a shot in the dark, but I hoped it was a common problem. I hear a rattle somewhere from the right front when the engine revs above 2500 RPM. For example shifting between gears, or when letting up on the gas. However when the engine is under load The sound goes away. It doesn't take much load either. Just giving it a slight amount of throttle the sound stops, but when I coast it comes back. I hear it too if I rev the engine while parked. It sounds like a heat shield vibrating, but I can't find one loose. I checked the front wheel bearing and it's good. Anyone have a similar problem? Thanks.
