HELP! cant get oil pan off z24 - Maintenance and Repair Forum
Saturday, May 24, 2014 11:32 AM
Ive been at this thing for a while, got all the bolts out except one. The pan is loose, but theres a bolt in the back on the driver side where there is a spacer of some sort directly underneath that bolt. I tried a swivel, and cannot get anything on it. Directly next to the flywheel.
The bolt that goes horizontally holding the bottom of the pan on, whatever encloses that bolt spins freely, like a sleeve or something but i cannot get above that with a 3/8 socket wrench. I believe its a 13mm bolt.
Any help would be astounding, thanks!!
Re: HELP! cant get oil pan off z24
Saturday, May 24, 2014 2:41 PM
sorry i couldnt answer you earlier, man.
idk how far you've gotten but there is a stud right there. you need to take that out, THEN you can remove the aluminum spacer.
RIP silver car. You will be missed.
Saturday, May 24, 2014 6:30 PM
Thanks man, Im sure thats what it is. I'll just double nut it and get it out. Or weld a nut on.
Monday, May 26, 2014 12:32 PM
It already has a nut on the end of the stud it is 7 mm.
