hard pedal, late shifting automatic - Maintenance and Repair Forum
Monday, June 02, 2014 11:32 PM
So while driving my car decides when itstarts the pedals Gunnar be like a feather then worse then gets hard and cars to push where I can push it Anyone but there is serrated part in my throttle body I found out earlier and my car clunks like my tranny is failing, BUT IT ONKY HAPPENS ABOUR ONCE A DAY BUT THE PEDAL STILL STAYS HARDwhen this happens and this jerks the whole car scares me honestly , so I pull over and go through the gears with with off switch the key a few times let everything reset ad sit And holding its bad trNny fluid I just leg it ruin through then I put in a at of it and just it idle then when I drove it drove like a champ no problems till about 45 mins later when it does it again, my guess is that it went though the dirty trans filter and now that oils the same as the rest, if anyone every had a hard pedal or if any if this makes sense pease let me know!
Horsepower is how fast you hit the wall,,,,,Torque is how far you take the wall with you
