2001 Z24 5 SPEED. NO GEARS.... - Maintenance and Repair Forum
Friday, June 27, 2014 5:28 AM
So I have a 2001 z24. 2.4L 5 speed. Just put a brand new motor & entire GM clutch system in...but been having issues with 5 gear grinding then 3rd gear wouldn't go in 80% of the time all the way,, that'd grind pretty harsh.
well yesterday I shifted to 4th and I have nothing. . the shifter is all slack.
It looked the gear shifter thing/gear selector on the transmission where the 2 shifter cables connect to popped out maybe a 1/8 inch.
Has anyone had this problem or know best way of replacing that piece or the actual name of it??
Thanks guys
Re: 2001 Z24 5 SPEED. NO GEARS....
Friday, June 27, 2014 2:34 PM
ANYONE?
Monday, August 11, 2014 5:54 AM
Sounds like something may have happened with the shift cables. Another possibility which I don't know it could've happened but grinding usually means the syncros are damaged. But my first thought would be to get those cables in order
Monday, August 11, 2014 9:55 AM
Tuesday, August 12, 2014 1:27 PM
Ended up putting a used transmission in over the weekend. Shifter shaft was f***** !!
shes all good now!
