2.2 Ecotec burns oil at WOT and oil turns black immediately after change - Maintenance and Repair Forum
Saturday, August 29, 2015 4:14 AM
I live in the Winston Salem area of NC. I have been the second owner of my 2004 Chevrolet Cavalier since March (its my DD) and cannot correct my oil burning issue. My engine burns oil above 3000rpm or if I'm engine braking downhill for an extended period of time (even in 5th gear). When I got the car it was pushing oil through the breather down to the throttle body. I corrected that problem by cleaning the port in the head and intake gasket it even solved my oil burning temporarily but it came back two weeks later.
Re: 2.2 Ecotec burns oil at WOT and oil turns black immediately after change
Saturday, August 29, 2015 4:15 AM
I am also having an issue with my oil turning black immediately after an oil change as in only 150 miles or less!!
Saturday, August 29, 2015 3:10 PM
Oil usually gets black fairly quick.
Saturday, August 29, 2015 4:36 PM
Rob Dotterer wrote:Oil usually gets black fairly quick.
How quick is fairly quick with Ecotecs?
I'm used to first Gen sbc V8s this is new to me.
Sunday, August 30, 2015 12:23 AM
Are you using synthetic? If you are, try 10w-30 synthetic. It seemed to slow my same leak down for me. People get less of a smoke screen when i hit the gas after engine braking down hills.
Do you find your car backfires a lot?
You really want to do something before you destroy your cat with oil.
Sunday, August 30, 2015 2:29 AM
Nicholas Reilly wrote:Are you using synthetic? If you are, try 10w-30 synthetic. It seemed to slow my same leak down for me. People get less of a smoke screen when i hit the gas after engine braking down hills.
With the flowmaster 60 there a little bit of a popping here and there when decelerating or tipping into the throttle slowly at low speeds. And I actually just got a P0420 two days ago. I've also ran a compression check on it after the mechanic I work with argued my rings were bad, it showed about 210psi on all cylinders. What are the odds the oil control rings are bad and the compression rings are good?
Sunday, August 30, 2015 2:31 AM
And I tried synthetic 10w30 even synthetic 10w40 with no change.
Sunday, August 30, 2015 9:43 AM
wow guys, my 2004 l61 cavy has 180,000 miles and doesnt burn a drop , however i have been using synthetic oïl from the start
BLACKMANTIS
Tuesday, September 01, 2015 8:16 PM
Is there a pile of oil in your intake pipe right before the throttle body?
