2001 Pontiac Sunfire TRAC OFF + High RPS + No Upshift??? (occasional) - Maintenance and Repair Forum
Thursday, October 15, 2015 12:38 PM
2001 Pontiac Sunfire, automatic trans, runs smooth; HOWEVER, occasionally the TRAC OFF light will illuminate and Sunfire won't accelerate past approx. 10mph - high RPMs as if maybe it's not upshifting like it should??? Turn off, restart, and runs fine until the next time... Check Engine Light on, previously only threw 2 codes P0221 (TPS) and P0440 (EVAP); cleaned throttle body, now only throwing code P0440. Please help, and thanks in advance!
Re: 2001 Pontiac Sunfire TRAC OFF + High RPM + No Upshift??? (occasional)
Thursday, October 15, 2015 12:43 PM
(Woops, trying to edit title...)
Re: 2001 Pontiac Sunfire TRAC OFF + High RPS + No Upshift??? (occasional)
Thursday, October 15, 2015 12:45 PM
I would replace the TPS sensor, and the IAT sensor. Both mess with the transmission a lot. I would also check the ground to the TPS and IAT sensors. Either one can make the trac off light come on.
The PO440 shouldn't mess / cause your conditions.
Thursday, October 15, 2015 1:04 PM
Thanks for your reply, -MD- Enforcer! Should it still be throwing a code for TPS if that needs to be replaced? The P0221 code has been gone for days after cleaning the throttle body. Related: Should IAT throw a code if there's an issue there?
(Unrelated: Can a mod edit the original title to reflect RPM instead of RPS?)
Wednesday, October 21, 2015 7:25 AM
IAT will not throw a code.
TPS may not throw a code, but may not be showing 0-100% if you can log the sensor.
IAT normally fail, and the car thinks it is VERY cold out.
