put a new headlight harness in my 99 Z24 today - Maintenance and Repair Forum
Monday, January 25, 2016 6:16 PM
The donor harness is from a 98 Z24 first I was told it will be fine, now I'm being told it will need to be re-pinned. everything that didn't work before now does with the exception of the turn signals and hazards.
Re: put a new headlight harness in my 99 Z24 today
Tuesday, January 26, 2016 3:06 AM
99 headlight harness and engine harness is 99 only. You can modify the 98 to work, but that is why your turn signals and hazards are not working.
Tuesday, January 26, 2016 4:55 PM
I looked up some diagrams, it's looks like it's two wires that are different, one says "+ battery voltage", the other says "left headlamp fuse/drl relay", all of those work fine.
Tuesday, January 26, 2016 5:00 PM
It is for sure more than 2 wires different. You may have to trace each wire to correct the issue.
Tuesday, January 26, 2016 5:10 PM
Ok, so if I was to unplug the front harness, would the dash and rear turn signals blink? I imagine they would, but faster than normal, because it thinks the fronts are burnt out.
Tuesday, January 26, 2016 5:39 PM
Yes.
Tuesday, January 26, 2016 6:02 PM
just tried it with the front harness unplugged, no change.
Thursday, January 28, 2016 12:13 PM
Update: It was the flasher cube!
