torque specs..intake mani and throttle body - Maintenance and Repair Forum
Monday, August 15, 2005 4:20 PM
if anyone knows this..can you please help me out and post it up...thanks in advance..
6ZILLA
MeanGreenGTP
Re: torque specs..intake mani and throttle body
Monday, August 15, 2005 4:26 PM
about 18 ft/lb
14.82 @ 97 mph
Monday, August 15, 2005 4:58 PM
about? are you sure about this? i think 18 is a bit much for the throttle body...anyone?
6ZILLA
Monday, August 15, 2005 5:24 PM
2.2L Torque Specs
Fastener Tightening Specifications
Application
Nm
Lb Ft
Lb In
Accelerator Cable Mounting Bracket
25
18
Accessory Bracket Assy. to Block Bolts
50
37
Camshaft Sprocket
130
96
Camshaft Position Sensor to Block Bolt
10
89
Camshaft Thrust Plate
12
106
Camshaft Rear Cover Bolts
12
106
Connecting Rod Cap Nuts
52
38
Coolant Drain Plug - Cylinder Block
15
11
Coolant Outlet Adapter Bolts
11
97
Coolant Outlet
10
89
Coolant Pump
25
18
Coolant Pump Inlet
25
18
Crankcase Front Cover Bolts
11
97
Crankshaft Bearing Cap Bolts
95
70
Crankshaft Pulley to Hub Bolt
50
37
Crankshaft Pulley Hub to Crankshaft Bolts
105
77
Crankshaft Sensor
11
97
Cylinder Head Bolts -- Long
63 + 90
46 + 90
Cylinder Head Bolts -- Short
58 + 90
43 + 90
Direct Ignition System Coil Assembly
25
18
EGR Valve
26
19
Engine Lift Bracket Bolt
50
37
Engine Lift Bracket Nut
50
37
Engine Mount Strut Bolts
100 +90
74 + 90
Engine Mount Strut Bracket Bolts (Rear)
75
55
Engine Mount Strut Bracket Bolts (Front)
66
49
Engine Mount Assembly Cage Nuts
45
33
Engine Mount Assembly-to-Body Nuts
66
49
Engine Mount Assembly-to-Drive Belt Tensioner Bracket Bolts
60
90
44 +
90
Exhaust Manifold Nuts
50
37
Flywheel Bolts
75
55
Lower Intake Manifold Nuts
33
24
Lower Intake Manifold Studs
10
89
Upper Intake Manifold Bolts
30
22
Lifter Guide
11
97
MAP Sensor
3
27
Oil Fill Tube
50
37
Oil Filter
17
13
Oil Filter Connector
35
26
Oil Pan
10
89
Oil Pump Cover Bolts
10
89
Oil Pump Drive Assembly
25
18
Oil Pump Mounting Bolt
44
32
Oxygen Sensor
42
31
PCV Valve Cap
10
89
Power Brake Hose Vacuum Fitting
13
115
Rocker Arm Nuts
30
22
Rocker Arm Studs
50
37
Rocker Arm Cover Bolts
10
89
Serpentine Drive Belt Bracket Bolt
50
37
Serpentine Drive Belt Tensioner Bolt
50
37
Spark Plugs
17
13
Timing Chain Tensioner Bolts
24
18
_________
2200 torque specs
Application
Specifications
Metric
English
10 Nm
89 lb in
Accessory Bracket Bolts
50 Nm
37 lb ft
Accessory Drive Belt Idler Pulley
50 Nm
37 lb ft
10 Nm
89 lb in
12 Nm
106 lb in
Camshaft Sprocket
130 Nm
96 lb ft
Camshaft Thrust Plate Bolts
12 Nm
106 lb in
Clutch Cover and Pressure Plate Assembly Bolts
First Pass
20 Nm
15 lb ft
Final Pass
45 degrees
52 Nm
38 lb ft
11 Nm
97 lb in
Crankshaft Main Bearing Cap Bolts
95 Nm
70 lb ft
105 Nm
77 lb ft
50 Nm
37 lb ft
Crankshaft Sensor Bolt
8 Nm
72 lb in
First Pass
63 Nm
46 lb ft
Final Pass
90 degrees
First Pass
58 Nm
43 lb ft
Final Pass
90 degrees
25 Nm
18 lb ft
50 Nm
37 lb ft
45 Nm
33 lb ft
Engine Mount Assembly to Accessory Bracket Bolts
First Pass
60 Nm
44 lb ft
Final Pass
90 degrees
Engine Mount Assembly to Body Nuts
66 Nm
49 lb ft
First Pass
100 Nm
74 lb ft
Final Pass
90 degrees
66 Nm
49 lb ft
75 Nm
55 lb ft
13 Nm
118 lb in
Flywheel Bolts
75 Nm
55 lb ft
24 Nm
17 lb ft
24 Nm
17 lb ft
12 Nm
105 lb in
Knock Sensor
19 Nm
26 lb ft
Lifter Guide
11 Nm
97 lb in
Oil Fill Tube
50 Nm
37 lb ft
Oil Filter
17 Nm
13 lb ft
Oil Filter Adapter
35 Nm
26 lb ft
Oil Gallery Plug (Large) - at Rear of Engine Block
33 Nm
24 lb ft
Oil Gallery Plug (Small ) - at Rear of Engine Block
15 Nm
11 lb ft
Oil Gallery Plugs - at Side of Block above Oil Filter
21 Nm
15 lb ft
Oil Pan
10 Nm
89 lb in
Oil Pressure Sensor/Switch
12 Nm
106 lb in
10 Nm
89 lb in
25 Nm
18 lb ft
44 Nm
32 lb ft
Oxygen Sensor
42 Nm
31 lb ft
Rocker Arm Bolts
25 Nm
19 lb ft
10 Nm
89 lb in
50 Nm
37 lb ft
Spark Plugs
17 Nm
13 lb ft
Throttle Body to Intake Manifold Bolts
10 Nm
89 lb in
24 Nm
18 lb ft
Water Jacket Drain Plug
15 Nm
11 lb ft
Water Outlet Pipe
26 Nm
19 lb ft
Water Pump
25 Nm
18 lb ft
Water Pump Inlet
25 Nm
18 lb ft
Water Pump Pulley Bolts
30 Nm
22 lb ft
2.4l Torque Specs.
Application
Specifications
Metric
English
Balance Shaft Cover Nut and Bolt
13 Nm
115 lb in
Balance Shaft Driven Sprocket Bolt (left hand thread)
First Pass
40 Nm
30 lb ft
Final Pass
45 degrees
Balance Shaft to Housing Bolts 8 mm hex
First Pass
10 Nm
89 lb in
Final Pass
40 degrees
Balance Shaft Housing Bolts 10 mm hex
First Pass
15 Nm
11 lb ft
Final Pass
40 degrees
Balance Shaft to block Bolts 13 mm hex
First Pass
25 Nm
18 lb ft
Final Pass
70 degrees
Balance Shaft to block Bolts 15 mm hex
53 Nm
39 lb ft
Balance Shaft to Block Bolts 18 mm hex
First Pass
40 Nm
30 lb ft
Final Pass
60 degrees
Camshaft (exhaust) Rear Cover
14 Nm
124 lb in
Camshaft Housing Bolts
Tighten the camshaft housing to cylinder head bolts to 22 Nm (16 lb ft) + 90 degrees.
Tighten the camshaft housing cover to camshaft housing bolts to 22 Nm (16 lb ft) + 30 degrees.
Camshaft Position Sensor Bolt
10 Nm
89 lb in
Camshaft Sprocket to the Camshaft Bolt
70 Nm
52 lb ft
Connecting Rod Nuts
First Pass
25 Nm
18 lb ft
Final Pass
80 degrees
Coolant Bleeder Valve
Fully Driven, Seated , Not Stripped
Coolant Outlet to Cylinder Head
26 Nm
19 lb ft
Coolant Pump to the Timing Chain Housing
26 Nm
19 lb ft
Coolant Pump to the Coolant Pump Cover
14 Nm
124 lb in
Coolant Pump Cover to the Block
26 Nm
19 lb ft
Crankshaft Balancer to the Crankshaft
First Pass
175 Nm
129 lb ft
Final Pass
90 degrees
First Pass
20 Nm
15 lb ft
Final Pass
90 degrees
Crankshaft Position Sensor to Block
9 Nm
80 lb in
Cylinder Head Bolts
Refer to Procedure
(9) (3) (1) (5) (7) (9 and 10 are the bolts on the pass side of engine)
(10) (4) (2) (6) (8) (torque bolts in sequence from 1-10)
Install and tighten the cylinder head bolts in sequence. Tighten
Tighten bolts 1-8 to 65 Nm (40 lb ft).
Tighten bolts 9 and 10 to 40 Nm (30 lb ft).
Then turn all the bolts an additional 90 degrees in sequence,
Engine Coolant Air Bleed Pipe
14 Nm
124 lb in
Engine Coolant Air Bleed Pipe Nut
42 Nm
31 lb ft
Engine Coolant Temperature Sensor to the Coolant Outlet
11 Nm
97 lb in
Engine Coolant Temperature Gauge Sensor to the Water Outlet
Fully Driven, Seated, Not Stripped
Engine Lift Bracket
96 Nm
68 lb ft
Engine Mount Bracket Adapter to Block Bolt Manual Trans
First Pass
60 Nm
44 lb ft
Final Pass
60 degrees
Engine Mount Bracket Adapter to Block Bolt Auto Trans
First Pass
60 Nm
44 lb ft
Final Pass
60 degrees
Engine Mount (right hand side) to the Engine Mount Bracket Bolts
62 Nm
46 lb ft
Engine Mount (right hand side) to the Body Support Nut
44 Nm
32 lb ft
Engine Mount (right hand side) to the body support bolt
66 Nm
49 lb ft
Engine Mount Strut
100 Nm
74 lb ft
Engine Mount Strut Bracket Front Bolts
66 Nm
49 lb ft
Engine Mount Strut Bracket Bottom Bolts
130 Nm
96 lb ft
EVAP Canister Purge Valve Solenoid Bracket Bolt
8 Nm
72 lb in
Exhaust Manifold Upper Heat Shield to the Manifold Bolts
26 Nm
19 lb ft
Exhaust Manifold to the Cylinder Head Nuts
42 Nm
31 lb ft
Exhaust Manifold to the Cylinder Head Studs
11 Nm
97 lb in
Exhaust Manifold Brace to the Exhaust Manifold Bolt
56 Nm
41 lb ft
Exhaust Manifold Brace to the Oil Pan Nuts
26 Nm
19 lb ft
Flywheel to Clutch Cover
First Pass
20 Nm
15 lb ft
Final Pass
45 degrees
Flywheel to the Converter
66 Nm
49 lb ft
Flywheel to the Crankshaft
First Pass
30 Nm
22 lb ft
Final Pass
45 degrees
Front Cover to the Timing Chain Housing
12 Nm
106 lb in
Fuel Pipe Bracket to the Camshaft Housing
First Pass
15 Nm
11 lb ft
Final Pass
30 degrees
Fuel Pipe to the Fuel Rail Nut
30 Nm
22 lb ft
Fuel Rail to the Camshaft Housing
26 Nm
19 lb ft
Ignition Coil and Module Assembly to the Camshaft Housings
22 Nm
16 lb ft
Intake Manifold to the Cylinder Head Bolts/Nuts
24 Nm
18 lb ft
Intake Manifold to the Cylinder Head Studs
11 Nm
97 lb in
Knock Sensor
20 Nm
15 lb ft
Oil Filter Connector to the Block
29 Nm
21 lb ft
Oil/Air Separator To Block Bolts
24 Nm
18 lb ft
Oil Dipstick Tube Bolt/Screw
8 Nm
71 lb in
Oil Filter to the Block
3/4 to one complete turn after gasket contact
Oil Pan Bolts
24 Nm
18 lb ft
Oil Pan Bolts, Second Set
12 Nm
106 lb in
Oil Pan Drain Plug
26 Nm
19 lb ft
Oil Pan Studs
26 Nm
19 lb ft
Oil Passage Plugs, Block 1/8x27
10 Nm
89 lb in
Oil Passage Plugs, 3/8x18
30 Nm
22 lb ft
Oil Passage Plugs, 1/4x18
20 Nm
15 lb ft
Oil Passage Plug Bolt
30 Nm
22 lb ft
Oil Pressure Switch
14 Nm
124 lb in
Oil Pump to the Balance Shaft Housing
12 Nm
106 lb in
10 Nm
89 lb in
Oxygen Sensor To Exhaust Manifold
42 Nm
31 lb ft
Powersteering Pipe to the Pump Nut
27 Nm
20 lb ft
Powersteering Pump to the Cam Carrier Bolts
26 Nm
19 lb ft
Rear Crankshaft Seal Housing to Block
12 Nm
106 lb in
Spark Plugs to the Cylinder Head
18 Nm
13 lb ft
Starter to the Block Bolt
90 Nm
66 lb ft
Tensioner to Tensioner Bracket Nut
54 Nm
40 lb ft
Timing Chain Housing to the Camshaft Housings
26 Nm
19 lb ft
Timing Chain Housing to the Block Bolts/Studs
29 Nm
21 lb ft
Timing Chain Tensioner to Housing and Block
10 Nm
89 lb in
Throttle Body to the Intake Manifold
10 Nm
89 lb in
Thrust Plate to the Balance Shaft Housing
13 Nm
115 lb in
Transaxle To Block Bolt
58 Nm
43 lb ft
Transaxle To Block Nut
66 Nm
49 lb ft
Transaxle To Block Stud
13 Nm
115 lb in
Sunday, March 06, 2016 2:10 PM
The accessory bracket on the 2.2L ('96 anyway) doesn't bolt to the block but rather the aluminum cylinder head. Not sure if 37 ft./lbs is over-doing it a little there or not?
