leaking OIL?? from the valve cover? help - Maintenance and Repair Forum
Monday, February 28, 2005 1:16 PM
This bolt on my valve cover seems to be leaking some oil, wut are the causes of this? How do i go about fixing it? is it easy? Do it yourself? or take it somewhere?
thanks
Re: leaking OIL?? from the valve cover? help
Monday, February 28, 2005 1:28 PM
um.... take off the vavle cover and replace the gasket?
take like 10-15 mins tops. make sure u got the correct trq for the bolts too.
if u wanted to be fancy you could clean it up and spray paint it, idk red to match your car.
-Borsty
Monday, February 28, 2005 2:02 PM
where do i get a gasket? auto store im sure... lol or if im wrong help me
and it just has 3 bolts holding it down? so pop it off and replace it? eazy as pie?
can i get a little more detailed instructions? i work better with detailed directions
thanks
Monday, February 28, 2005 2:23 PM
send me a pm ill explain.
-Borsty
Monday, February 28, 2005 5:35 PM
The valve cover gaskets on the 2.2 don't hold up very well. just replace the gasket and that should take care of the problem
Monday, February 28, 2005 5:39 PM
You can pick up the gasket from you local dealership. The part # is 024576310.
It should only cost about $10. But i wouldn't go with a aftermarket part.
Monday, February 28, 2005 8:49 PM
why not an an aftermarket part? just curious
