What year is my 2.2 Block - Maintenance and Repair Forum
Friday, March 04, 2005 8:00 PM
i got a 2.2 engine in my garage, but i'm not sure what year its from, i'm sure its from a second gen, either 92-94, the oil filter goes directly onto the block. here are some pics, can anyone tell the exact year from the pics?? Or, where is the Serial # loacted on the block, i couldnt find one.
P.S. i asked this question a while ago and was given this link, but it doesnt work http://www.ny-jbodies.org/forums/library/engine/2.2/2.2history.htm
Re: What year is my 2.2 Block
Friday, March 04, 2005 9:24 PM
Are you sure it's from a 2nd gen? I ask because it looks identical to the one in my '95 3rd gen... Though I know they used the 2.2L OHV in both 2nd and 3rd gens, maybe there is some distinguishing marks?
Saturday, March 05, 2005 12:20 AM
the only real distinguishing things are the alternator bracket. the 2nd gen's had a weird "v" shaped bracket, and the intake manifold tell's me it's not TBI or SFI. can't see the exhaust manifold. this engine is 94-97. i believe the serial number is around where the tranny bellhousing bolts up to the block.
Saturday, March 05, 2005 9:07 AM
i'm pretty sure its a 2nd gen, i saw the car and it wasn't a 3rd gen. he was doing a 3.1 swap. i'll check the number later on
Sunday, March 06, 2005 1:13 PM
The Trottle Body, Intake, valve cover, the back side, and the transmission look identicle to my 96 Cav 2.2... Another vote for 94-97 engine.
Sunday, March 06, 2005 4:18 PM
so there is no chance its a 93 and under???????
Sunday, March 06, 2005 4:28 PM
black valve cover.. it's a 2.2 from a second gen me thinks.. is there a vin number or identification number on there? should be on the front of your block etched in
2004 Nissan Maxima SE w/ Elite Pkg
2005 Infiniti G35 Coupe w/ Sport Pkg
Sunday, March 06, 2005 7:44 PM
i can't find it anywhere, the block has alot of rust and dirt on it sor its hard to find a number, does anyone know where the ID# is exactly? I know for a fact that it came out of a 2nd gen, so that rules out 95-97...so its 94 or older. here is a pic of the exhaust manafold...
Monday, March 07, 2005 5:49 AM
i would say by looking at the alternator bracket in the photo its a 92-93.
from 92-97 they all look visually the same, just the internials are differant from 94-97.
<img src="http://midvalespeedway.com/images/drivers/C-958-0.jpg" width="300" height="195">
Monday, March 07, 2005 12:13 PM
Looking to the right of the exhaust, all the way back where the block meets the trans there is a inch wide machined area, the numbers are there.
Monday, March 07, 2005 3:36 PM
OK, i just found a small factory etched number INS802510, but i cant find that number anywhere on this 2.2 history page http://www.ny-jbodies.org/library/engine/2.2/2.2history.htm
Monday, March 07, 2005 7:48 PM
you can tell its a 2nd gen by the tensioner plate......um i would say anywhere from 92-94 being MPFI and all
Monday, March 07, 2005 7:50 PM
im saying its a 1990-1993 2.2.....it has the newer TB setup, so its not 88 or 89 2nd gen
Monday, March 07, 2005 8:25 PM
it can't be a 90-91 because it doesn't have a oil filter adapter, and 94 has a roller cam,
Tuesday, March 08, 2005 6:12 AM
it can not be a 90-91 2.2l because its multi port . they changed the style of alternator brackets in 94,and has the wrong tensinior pulley to be a 95-97. so it leaves you to be either a 92-93.
Tuesday, March 08, 2005 7:52 AM
ohhh. 94. i said 94-97.
Tuesday, March 08, 2005 8:33 AM
Does that number i posted say what year it is, it was right where the tranny meets the block,
Tuesday, March 08, 2005 9:03 PM
the VIN should be stamped on the block and 8th digit from the last one is the model year..
eg. 1g1jc5246T710001 in this case t would mean 1996.
s = 1995
t = 1996
v = 1997
w = 1998
x = 1999
y = 2000
you can also find it right before where the bellhousing/tranny meets the block.
hope that helps.
Thursday, March 10, 2005 2:21 PM
i couldnt find a VIn on the block, just that number i posted it was engraved beside the starter near where the engine meets the tranny, and anyone decode the number??/
