95 cav feels like stalling when coming to stop - Maintenance and Repair Forum
Friday, March 11, 2005 8:24 AM
we changed the air filter, changed the plugs, wires, next thing we were gonna do is change the oil & oil filter...
this car feel like it's going to stall out when we come to a stop...
anyone know the cause of this? automatic transmission, not manual..
Re: 95 cav feels like stalling when coming to stop
Friday, March 11, 2005 10:08 AM
Torque Converter Clutch fails to release and causes the car to stall when it comes to a stop. Most of the time it is a stuck Torque Converter Clutch (TCC) solenoid.
Try To Unplug The Solenoid From The Transmission, Then Take Car For A Ride, If It Stays Running While Comming To A Stop Then You Need To Replace The Solenoid.
Just To Let You Know Alot Of Memembers Had This Same Promblem,And Alot Of Them Say To Just Leave The Solenoid Unpluged And It Will Run Fine.
Hope This Helps
<img src="http://midvalespeedway.com/images/drivers/C-958-0.jpg" width="300" height="195">
Friday, March 11, 2005 10:31 AM
wow, that sounds crazy, where is this solenoid located? do I have to drop the tranny or anything to access it?
thanks for the tip!
Friday, March 11, 2005 2:24 PM
do u stock motor mounts? mine did this when i had poly mounts in...
Friday, March 11, 2005 4:12 PM
95CavBlue wrote:do u stock motor mounts? mine did this when i had poly mounts in...
i doubt that motor mounts would even be close.......i also say the TCC solenoid
Friday, March 11, 2005 4:14 PM
the TCC switch is located in the trans...you have to remove the side cover of the trans and the switch will be right there......hope this helps any..
Friday, March 11, 2005 8:34 PM
i'd say fuel pump, but im an idiot
Saturday, March 12, 2005 6:44 AM
how do you test a fuel pump
Saturday, March 12, 2005 7:49 AM
I'd say TCC solenoid
