Signal Lights & DRLs - Maintenance and Repair Forum
Tuesday, April 19, 2005 5:21 AM
I'm having the DRL issue where when i put my ebrake down and the car is on the light on the dash flashes and you hear the relay click a bit and the DRLs dont come on.
i've replaced one driver side marker bulb as it was out - all my other lights work - the relay checks out fine.
i have a feeling it might be a wiring issue as my highbeams seemed to flicker a bit so there might be something to check there.
the question I have is are the signal lights supposed to be on all the time when I turn the headlights on?
right now if i turn the headlights on everything comes on but the signals dont come on until i turn on the 4ways or set the switch to turn left or right.
are the signal lights supposed to be on all the time??
- T
Re: Signal Lights & DRLs
Tuesday, April 19, 2005 5:29 AM
When you turn your headlights on your corner and bumper lights should come on
af
Tuesday, April 19, 2005 5:37 AM
thanks - now i know what to look for
- T
Tuesday, April 19, 2005 6:32 AM
normally when that DRL light flashes it tends to mean some sorft of light is out. Check all and go from there.
dan
Representing the 810's ... biatch!!
[19:33] Lurch: I am sick of sex! (and you thought it would never happen)
*dan says: "lil' d ... do you have some skeletons in your closet"??
sandstorm says: "$%^!, Ive been caught ".* OWNED!!!!
Tuesday, April 19, 2005 7:36 AM
I agree with Dan. Most people have come to accept a "strobing DRL" as a general burnt-out-light-somewhere indicator.
~ The Deviant One ~
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/personal_pic.gif">
Tuesday, April 19, 2005 9:49 AM
im a nice guy and like repeating myself..check the harness just below the battery that goes to the headlights.. i bed you have some corroded wires there..mine did the same thing until i cut and resoldered the wires back together.
