spare cooling fan - South Pacific Region Forum
spare cooling fan
Wednesday, March 23, 2005 3:16 PM
I was wondering if there is anyone in the LA area that has a spare cooling fan I can buy or borrow. I'm not sure is my cooling fan is broken or I fried the wiring to the fan trying to do the fan override mod.
Thanks in advance
Sal
Re: spare cooling fan
Wednesday, March 23, 2005 3:34 PM
You can't test the fan by putting power to it directly?
Can't test the circuit for voltage drop?
^^Home made sig^^ ghetto, I know. http://members.cardomain.com/blackoutfire
Wednesday, March 23, 2005 4:59 PM
How do you do that? Do i take a voltmeter and hook it up to green wire on the fan? Where do i attach it?
Thanks
Sal
Wednesday, March 23, 2005 5:36 PM
To check the fan: you put one wire to the positive terminal on the bat. and the other end goes to one terminal on the fan plug.
Then you can attach the other prong on the fan connector to a ground ( if bat connected properly)
If the fan turns on it's good and you have a short or open elsewhere.
Wednesday, March 23, 2005 5:37 PM
Wednesday, March 23, 2005 5:38 PM
eh, triple post.
Wednesday, March 23, 2005 6:46 PM
or you can pull the under hood relay, jump 2 wires, not sure which ones othe than you use the diagnaol ones.
Wednesday, March 23, 2005 7:26 PM
That too!
It should have a diagram of the circuit on the relay. So jump the two wires that arn't the coil/ magnet wires.
Friday, March 25, 2005 6:34 PM
I did the direct wiring thing to the fan and it worked. So is this a relay or wiring problem where teh fuse box is located?
Thanks in advance
Sal
