Direct Bolt On TB For The 2.2 - Performance Forum
Monday, March 14, 2005 8:19 PM
Are there and TBs from and other engines that can bolt on to the 2.2 without much modification.
Re: Direct Bolt On TB For The 2.2
Monday, March 14, 2005 8:33 PM
i just put a 2.3 tb on my 2200. no mods just used the tb and bracket had to turn the bracket backwards though took me a while to figure out. i think it is pretty nice. car runs smoother to. some guys had to grind the tb a little i didnt. it would hang up the first couple time i would WOT but i just wore it in by closing and opeing it and now it is awsome. hope this helps ya
Monday, March 14, 2005 9:09 PM
what year cav did this come in?
<img src="http://registry.gmenthusiast.com/images/h8hondaz/sig.jpg">
Monday, March 14, 2005 9:20 PM
Just to clear this up this only works on the '98 and newer 2200
'99 2200 LS CX1 Sport
Monday, March 14, 2005 9:46 PM
^^^^^^ i guess i should of said that too but i have a 2002 thats why it worked on mine
Tuesday, March 15, 2005 4:06 AM
I could put a 2.3 TB on my 2001 2200?
Tuesday, March 15, 2005 6:30 AM
^^^you can put a 2.3 tb on your 2200. you can find these tbs on 95 cav z24s and sunfire gts but also any other car that came with the 2.3, doesnt matter if it is a HO or LO. mine came from a 92 grand am i believe.
Tuesday, March 15, 2005 6:48 AM
hey blucav, i just replied to your other post about the tb
Tuesday, March 15, 2005 9:25 AM
any 2.3 TB or does it have to be from specific years? what about one from a 2001 grand am?
Tuesday, March 15, 2005 9:27 AM
never mind those are 2.4s... you say the 92 grand am TB bolted right on?
Tuesday, March 15, 2005 9:42 AM
I ordered one from a 95 sunfire. do you think it will be ok? will my intake still fit?
Tuesday, March 15, 2005 12:15 PM
the tb does bolt on with slight modification. the one you ordered will be ok as long as it was from a sunfire gt because they had a 2.3. if it is not a gt, it wont work. your intake should still fit, mine fit without a problem
Tuesday, March 15, 2005 2:36 PM
My Sunfire is a 96 so will the 2.3 tb still work?
Tuesday, March 15, 2005 2:56 PM
no, 98 and newer 2200 only. you will probably have to buy one made to fit the 95-97 2.2
Tuesday, March 15, 2005 3:16 PM
rsm sells them for 2.2 95-97 check them out, less hassle.
Tuesday, March 15, 2005 4:18 PM
ok good.... They never said wheather it was from a GT or not. but I will call tomorow and verify that it is. Even if it doesn't fit I may be able to sell it as a core for someone that needs to bore it. If I do get it to fit good, I will sell my 2.2 for core.
