 you are here: / home / forum
Tuesday, February 9, 2010
2.2 OHV Valve Adjustment (for roller rockers) - Performance Forum
Discussions about performance modifications to j-body automobiles which do not involve any kind of forced induction or nitrous. Topics in any way related to turbo or supercharger should go in the Boost forum, and nitrous topics in the Nitrous Oxide forum.
Go To TopSearchOptionsRulesHelp
Previous MessageNext Message
 Current Page: 1 of 2
Go To Page: 12Next
Thursday, December 08, 2005 10:32 AM
On the 2.2 OHV in stock form, there is no valve adjustment needed, or at least this is what GM says. The hydraulic lifters adjust valve lash automatically. All you need to do is torque your top nuts on your rocker arms down to 22 ft/lbs.
However, when using the 1.6 roller rockers on either engine with adjustable rocker studs (that are needed when doing the roller rockers on the 2.2 or 2200). Below is a chart that I decided to put together to avoid confusion when adjusting valve lash. You will spin the motor over a total of 4 revolutions. Make sure it is at TDC when you start.
IMAGE REMOVED
I hope this makes sense to everyone. The alternate method column is shown after 2 revolutions because you have already completed one cycle.
And personally I think this should be stickied.
Edited 1 time(s). Last edited Saturday, July 29, 2006 6:02 PM
Advertisement
Upgrade to premium membership to remove this ad.
Re: 2.2 OHV Valve Adjustment (for roller rockers)
Thursday, December 08, 2005 10:46 AM
Sorry man, you're not going to get a sticky just for this However, anyone making an OHV build-up guide (or something similar) should put this into it.
You may want to specify exactly what 1/2 turn means (with respect to what?) though.
fortune cookie say:
Thursday, December 08, 2005 10:48 AM
1/2 turn means basically with your socket on the top nut of the rocker arm stud, a half turn is about what it works out to be before it's tight. i forgot to mention, this is typically a 2 person job. one person rotates the motor by hand with a socket on the crank pulley
Thursday, December 08, 2005 11:06 AM
Haha, I have to give a 'duh' to the turning the nut 1/2 turn *lol
I meant you need to specify '1/2 turn after the rocker makes contact with both the pushrod and the valve stem'. I believe this should work out to about the same as how I was told to do it way back when. They should be tightened as much as possible while still being able to rotate the pushrod in the rocker bowl with your forefingers.
fortune cookie say:
Thursday, December 08, 2005 11:23 AM
Yup you got it. I figured that'd be pretty self explanitory but... then again, yea nevermind.
Thursday, December 08, 2005 11:24 AM
you guys crack me up
Thursday, December 08, 2005 11:54 AM
Don't the 2200s have 1.6 full roller rockers from the factory? I thought I read that somewhere on here.
"Silly cluth, glazing is for donuts!"
Thursday, December 08, 2005 12:27 PM
they have roller rockers but not a roller end. and the stock lift is said to be 1:6 but more something like 1:54 i think
Thursday, December 08, 2005 1:18 PM
that's correct. i haven't looked at the factory 2200 rocker arms, but I also believe the rocker studs are similar to the 95-97 OHV and are not adjustable
Thursday, December 08, 2005 1:36 PM
Web PageAOL IMPhoto
Yup, the 2200 has a cast steel roller fulcrum, the tip still rubs on the valve stem. Alot better than the old pivot ball fulcrum, but not as good as the full roller rockers that Crane makes. The Comp Magnum rockers are an improvement over the stockers, because they are ratio accurate (the stocker are far from it) and have almost no flex under load, but their downfall is they use the pivot ball fulcrum.
Thursday, December 08, 2005 1:42 PM
I see. I was wondering, I have the 1.6 conversion on my LN2 turbo motor, and since it's blown up, I'm going to pull some of the useable parts and put them on my other Cavalier. So the question I have now, is what would the advantage of going full roller instead of the pivot ball type I have now? Is there any more power from upgrading even further? I'm going to go all motor this time around, so what do you think? I don't mean to jack the thread but since we're pretty much on the same topic...
Thursday, December 08, 2005 1:52 PM
friction is the answer, you get much much les friction with the full roller sets.
Thursday, December 08, 2005 1:55 PM
Web PageAOL IMPhoto
Most of the gains (on the 2200) come from the ratio accuracy, when using the Comp rockers. On the 2.2s, most of the gains come from the ratio accuracy and the elimination of flex (stamped rockers flex allot). The roller fulcrums on the Crane rockers, reduce the frictional losses and run much cooler that the pivot balls. The roller tip helps very little, the fulcrum is the most important part. Read Did You Know at the bottom of this newsletter.
Thursday, December 08, 2005 9:29 PM
ooo my first sticky I'm so happy. Phlatcav, do you have the ARP numbers for the 2200 rocker studs to add to this?
Thursday, December 08, 2005 9:37 PM
I also should add, that the 1/2 turn for adjustment is after you reach ZERO LASH. Which is basically when the roller makes contact with the valve stem and the pushrod
Thursday, December 08, 2005 10:20 PM
Sadly no but i do know the the top and base thread so finding a set at summitracing.com or jegs.com is easy.
98 2200 = 10mm base with 3/8 top
99+ 2200 = 8mm base with 3/8 top
Thursday, December 08, 2005 10:30 PM
Here are the ARP part numbers I found.
8mm base with 3/8 top 99+2200
ARP-134-7201 = Rocker Arm Studs, High Performance, 3/ 8-24 in. Thread, 1.75 in. Effective Stud Length, Chevy, Vortec, Kit
10mm base with 3/8 top 98 2200
ARP-100-7201 = Rocker Arm Studs, High Performance, 3/ 8-24 in. Thread, 1.595 in. Effective Stud Length, GM, V6, Kit
There ya are
Thursday, December 08, 2005 10:32 PM
Part numbers for ARP main and head studs....
Main studs...
ATP4.400-1LB x8 these will be for main caps 1-4
ATP4.650-1LB x2 these are for the rear main cap where the oil pump mounts, they ned to be slitghly longer.
APW1316 x 10 these are the hardended steel flat washers
APN12-1 x 10 these are the 12 pt hardedned steel nuts.
head studs....
ATP4.650-1lb x 5 these are the shorter studs by the exhast ports retail price 6.93 each
ATP5.950-1 X 5 these are the custom length needed for the other studs retail price 10.50 each
APW1316N x 10 these are the washers retail price .75 each
APN12-2 x 10 these are the 12pt nuts retail price 1.73 each
Thursday, December 08, 2005 11:16 PM
AOL IMPhoto
hey just wondering which are the best roller rockers for performance on the 2200 and whether replacement of the springs pushrods lifters and studs are necessary in the process... later
Thursday, December 08, 2005 11:24 PM
I would say the Crane 1:6 rockers would be about the best performer. If you deside to upgrave the valvetrain be sure to do your home work or it will be headaches later on, god knows im having one trying to get my springs, keepers, and retainers right
Thursday, December 08, 2005 11:25 PM
wooops, just realized this sticky was for the rockers and not a full build guide
Friday, December 09, 2005 12:31 AM
I'm sure once we get a build guide done, Dave can integrate it with my chart and explanation, and rename the thread
Friday, December 09, 2005 8:56 AM
AOL IMPhoto
You should probably mention what cylinder needs to be at TDC when you start. Those of us that have done this beofre know, but for someone just doing it now, it would be helpful.
GMSC Bash '05- 2nd place 82-94 Modified
V6Z24.com Bash '05- 2nd place Show & Shine
MoHud SCCA SOLO II '04- 1st place SM
Premium Member since 4/02------------YOUR TAX DOLLARS AT WORK!
Visit-----Team Dropzone-----and-----Sports Car Club of America
Friday, December 09, 2005 3:31 PM
Cylinder 1 needs to be at TDC.
Tuesday, December 13, 2005 9:42 PM
Correction on ARP part numbers for head and main studs!!!
For the head studs the final part numbers are:
5 x ATP4.510L M11x1.5 STUD x 4.510"
5 x ATP5.950-1 Custom M11x1.5 STUD
10 x APN12-2 12 Point Nuts
10 x APW1316N Washers
For the Main Studs the Final Part numbers are:
10 x ATP4.400-1LB M11x1.5 & 7/16-20 STUD
10 x APN12-1 7/16-20 12PT Nut
10 x ARW1316 Washer 7/16ID 13/16OD Chamfe
Go To Page: 12Next
