So I did some searching and im still not quite sure how your supposed to make the egr work with the swap. Modifying the intake isnt a problem and Im fine with the rest just a little confused about the egr valve. any help is appreciated.
block off plate put up with the code
Yeah, block off plate is your best way to go. I would stay away from EGR simulators because I have read a lot about people having problems with them. I just got a code scanner and clear the code everytime I start the car so the fan doesn't run non stop. I think you can also swith over to a 99 PCM and that eliminates the problem with the CEL all together. I also thought I read about someone making an adapter that extends the EGR over the manifold so that it will fit and you can fit the line coming from the EGR into the front of the manifold. I have yet to see any developments on this but I am still very interested.
"Kneel before ZOD!!!"
I've read that extending the egr causes problems
so the blockoff plate does not throw codes....
you scratch my ride IMA EAT YO CHILDREN
Thanks...I can deal with a code as long as the engine runs right...
CzapskiKandyKav wrote:I've read that extending the egr causes problems
lol, im the only person who has done this. And i have NO check engine light going on 3 months. No problems what so ever. The adapters will be out soon, its been taking me ALOT longer then i expected (its hard to find parts to make the install easy, and cheap the price down).
http://www.j-body.org/forums/read.php?f=2&i=341452&t=338769#341452
Click the banner to enter the best Quad4 & Twin Cam site on the internet.
i have no check engine light and ive had my egr blocked for 2 months no problems what so ever
Paul Tjepkes wrote:i have no check engine light and ive had my egr blocked for 2 months no problems what so ever
Must be something wrong with your car then. Did you have the car scaned for codes at all? If you removed your EGR and just blocked the port off your going to get a check engine light (unless the bulb is burnt out).
I think the one I am thinking of is a little different than your setup urweak. I remember reading it somewhere wish I remember where
Make sure you let me know about your setup once you get parts set up.
CzapskiKandyKav wrote:I think the one I am thinking of is a little different than your setup urweak. I remember reading it somewhere wish I remember where
people have tried running a vac line to the EGR and tricking it that way. but that doesnt work. What i did, is the only way that works.
What did you do to make it work?
Thanks, I read it now lol...I am definitely interested in buying one of those when your ready to sell them.
ya thats the one I was thinking running the vac line
or you can do this...
[/IMG][IMG]
[/IMG]
yes it clears the resivoir for the P/S....with some modding
if any one is interested i stil got 2 block off plates for sale they work great check the classified
http://www.geocities.com/WIJTuners/?200511
wi jbody site
http://www.cwctekcom.com/ go here for some awsome deals on installs and awsome stereo stuff in new lisbon, WI
PhilioZ24 wrote:or you can do this...
[/IMG][IMG]
[/IMG]
Thats an interesting setup. Looks good. What is the yellow hose made out of?
the yellow hose is a standard gas line for a stove......i havent had any issues with it and no codes for EGR .....
theres a little more to it than just flipping it upside down.......if anyone wants pics lemme know
PhilioZ24 wrote:the yellow hose is a standard gas line for a stove......i havent had any issues with it and no codes for EGR .....
Yea, it looks that way. I am guessing you have 2 bolts holding it inplace instead of the normal 3? And i would guess you had to notch it some to get the gas to flow threw the stock mount upside down, or did you do something else. Also, how did you get it on an angle like that (for some reason it looks that way)?
PhilioZ24 you should write up on how you did it it looks good
hmmmm..................possibility...then i could become a name on the org that everyone knows.....lol....maybe i will ....
PhilioZ24 wrote:hmmmm..................possibility...then i could become a name on the org that everyone knows.....lol....maybe i will ....
yea that would be good. with that, theres probably no more need for me to make the mounting brakets i was working on.
PhilioZ24 - You should DEFInitly do a tech right you would help ME and many out EGR valve-less Org. members
Urweak- You should still try to make your mounting bracket its still a great idea
make the egr work with the gm s/c.
i am just clearing my egr code each time i start the car, takes 30 seconds with a code scanner. sorta a pain, but i am used to it.
