 you are here: / home / forum
Sunday, November 22, 2009
LE5 Intake Mani gains? - Performance Forum
Discussions about performance modifications to j-body automobiles which do not involve any kind of forced induction or nitrous. Topics in any way related to turbo or supercharger should go in the Boost forum, and nitrous topics in the Nitrous Oxide forum.
Go To TopSearchOptionsRulesHelp
Previous MessageNext Message
Friday, October 30, 2009 8:39 AM
AOL IMYahoo Messenger
Im considering using the LE5 intake manifold with a 62mm throttle body, bigger injectors, and a bigger fuel rail. What type of gains can I see with that?
R.I.P. HardcoreXSunfire...And introducing HardcoreXCavalier
Advertisement
Upgrade to premium membership to remove this ad.
Re: LE5 Intake Mani gains?
Friday, October 30, 2009 9:12 AM
A really crappy running car (if it'll run at all) without a tune to compliment. I did the LE5 intake mani with LSJ injectors and a tune, and my low end stayed the same, but after about 3500-4000 there's a marked difference in pull. I have yet to track or dyno it yet though (track is next friday, dyno is whenever I can come up with $50). I have yet to get my 63mm throttle body on, but that'll also help out throughout the rpm range. One quick note: the CrateEngineDepot adapter plate for the TB will need to be bored out to accept the larger TB and you'll need to drill the hole for the IAC valve pass-through into the mani.
Btw, you don't need a bigger fuel rail at all, your stocker is more than adequate until you start pushing a TON more power, or alcohol lol.
Friday, October 30, 2009 9:21 AM
AOL IM
I know there was a gain of close to 12whp on adding it to a 2.2 cobalt, there was a dyno run showing it on crate engine depots website.
Friday, October 30, 2009 10:07 AM
just the fuel rail gives ya 20whp
Friday, October 30, 2009 11:29 AM
AOL IMMSN MessengerYahoo Messenger
I know the gains on the Cobalt were impressive, WITHOUT a tune.
I gotta get mine and set my wideband up. I'll get proof if it leans out unsafely.
Friday, October 30, 2009 11:36 AM
AOL IM
im installing mine right now and i also have a wideband so once i get it on later ill tell you if it leans you out or not
Friday, October 30, 2009 11:40 AM
AOL IM
the cobalt is also able to adapt better having a mass air flow sensor as well, the J's ecu cannot change the variable on a stock tune and even with injectors will run lean.
Friday, October 30, 2009 1:36 PM
AOL IM
You'll need a tune. The fuel rail is wasted money IMO. There are decent gains to be had especially after the normal peak of 5500rpm.
Friday, October 30, 2009 1:59 PM
ICQAOL IMMSN MessengerYahoo Messenger
my car leaned out after 4500 rpms over 1.0 afr
so it def. flows A LOT more air. my problem is I need bigger injectors...
Friday, October 30, 2009 4:04 PM
AOL IM
yea i was at 90% idc before tuning with the mani installed...
Friday, October 30, 2009 5:17 PM
i forget to say i will be getting a tune as well. that goes without saying. so no need for bigger injectors or a bigger fuel rail?
Friday, October 30, 2009 5:20 PM
The fuel rail is completely unneeded, but the injectors would be a good idea. Get a set of LSJ injectors off of Cobaltss.net...they're usually around $50 sometimes less for all four.
Friday, October 30, 2009 5:29 PM
well the fuel rail i already have is from an 02 Ecotec which i was told is better? and it cost next to nothing. but i had planned on the LSJ injectors. im thinking this could be a good idea
Friday, October 30, 2009 7:46 PM
AOL IMYahoo MessengerPhoto
How is it up to 4500 rpm? Does it feel any better, run any better, or worse without a tune? Reason i ask is after i install mine it could be a week or so until i get a tune so i'm just curious. Thanks
Friday, October 30, 2009 9:17 PM
SO...how bout the LE5 vs a ported stock manifold?
Friday, October 30, 2009 9:28 PM
No, the LE5 manifold is alot higher flow, porting a stock 2.2 manifold will not have the same effect
15.0 @ 90mph with only a intake and exhaust.
Saturday, October 31, 2009 5:25 AM
it actually runs richer because I'm not moving enough air. we had it before that at wot it was 12.5 across the board. Now its like 11.3 @ 2k-4K and then goes way lean by 7k. at 7k Im over 13
Saturday, October 31, 2009 12:39 PM
So in order to use this manifold you need larger injectors and a ECU retune?
Saturday, October 31, 2009 3:59 PM
Pretty much that's what it amounts to, Ronin.
Saturday, October 31, 2009 8:47 PM
Bummer...seemed like it might be a cool afternoon project, but thats more than I need to get into.
Saturday, October 31, 2009 9:07 PM
Yahoo Messenger
if ya want shoot me an email roy_boy80@yahoo.com i got a set of of the LSJ injectors, fuel rail and the lines. just laying around no need for them anymore shoot me an offer shipped for what you want
sunfire gone she will be missed very much
