 you are here: / home / forum
Friday, November 20, 2009
Replacing engine, ideas? - Performance Forum
Discussions about performance modifications to j-body automobiles which do not involve any kind of forced induction or nitrous. Topics in any way related to turbo or supercharger should go in the Boost forum, and nitrous topics in the Nitrous Oxide forum.
Go To TopSearchOptionsRulesHelp
Previous MessageNext Message
Wednesday, November 04, 2009 7:54 AM
Im going to be replacing the high mileage ld9 this winter, and wanted some ideas on what can be done with the new engine before I drop it in. Dont want to tear the engine apart, its only a dd. Will be replacing all the old with new like water pump, timing chain, head gasket ect. But anything else you guys can think of to give it a bit of a face lift.
Advertisement
Upgrade to premium membership to remove this ad.
Re: Replacing engine, ideas?
Wednesday, November 04, 2009 8:37 AM
I was going to suggest secret cams but you have a 96, and cant get it tuned.
Screw it. Put the quad4 HO in.
http://WWW.AZGMPERFORMANCE.COM
Wednesday, November 04, 2009 6:13 PM
I say find a 4BT cummins and trans mission and make a 4 cyl cummins diesel cavy!!!
"It's called reading! Top to bottom, left to right... a group of words together is called a sentence. Take Tylenol for any headaches... Midol for any cramps."
Wednesday, November 04, 2009 11:47 PM
MSN MessengerPhoto
Even untuned, the secret cams are better than the stock cams.
Thursday, November 05, 2009 3:47 AM
AOL IM
2.3 oil system, HO mani, secret cams?
I know someone selling secret cams PM me if you're interested
Thursday, November 05, 2009 6:13 AM
Secret cams, 2.3 intake manifold and tb, header(pacesetter is cheap and decent), lighter crank pulley, and if you dont mind tearing into the bottom end and dont wana spend alot of money the 2.3 pump swap is a must.
I have an HO intake manifold with shaved runners painted black if your interested
Thursday, November 05, 2009 8:11 AM
AOL IM
Just get a LG0/LD2 Quad.... make your own "down pipe" and PS line, but its easy.
Chris
'02 Z-24 Supercharged
13.7 @102.45 MPH Third Place, 2007 GMSC Bash SOLD AS OF 01 MAR 08
205FWHP, 210FWTQ, STOCK PULLY
Team GREEN
Thursday, November 05, 2009 8:31 AM
I was thinking about all the above. Only thing is Im not that comfortable drilling holes in my block. I read the sticky on the 2.3 pump and it seems straight foward. I would do it if anyone want to give me hand .
Chris
What exactly is involved in this swap. I know theres tons of them in the yards around here.
Also what are the differences between a 95-99 ld9 and a 2000+ ld9? What is needed to drop in a 2000+ ld9 into a pre 99 car?
Edited 1 time(s). Last edited Thursday, November 05, 2009 8:37 AM
Thursday, November 05, 2009 9:48 AM
2000+ has no EGR. Knock sensor is different. Thats about it.
Get a LG0 or LD2. Its a shortcut to building an LD9.
Thursday, November 05, 2009 12:54 PM
Ok i Found a low mileage ld9 out of an 01 cheap. I know I will have to drill and tap for the bigger knock sensor. Anything else needs to be done for it to work? Whats the case with having no EGR?
Thursday, November 05, 2009 4:46 PM
Web PageAOL IMPhoto
I donlt think so.
Using a 2000+ motor in your car you are just going to use everything from your car. So you will still have EGR.
MD Motorsports
Monday, November 09, 2009 9:41 AM
John Higgins wrote:
I donlt think so.
yup... not by much, maybe 5 or 10 hp, and only above 3k rpm, but it is better than stock for sure.
Monday, November 09, 2009 1:37 PM
So going with the 01 motor I pretty much just have to strip it down . And Use the intake/exhaust mans, fuel rail,injectors and sensors from my 96?
Tuesday, November 10, 2009 4:33 PM
Anyone?
Thursday, November 12, 2009 4:39 AM
AOL IMMSN Messenger
You may need to swap over the EGR stuff IF the 01 has the previsions for an EGR. don't quote me on that though.
Thursday, November 12, 2009 7:01 AM
01's dont come with an egr.
you can remove it though and just make/buy a block off plate. no big deal as long as you dont mind living with a CEL
boosted then blown //first cavi with G6 seats
