Eco Fuel Rail Pressure - Performance Forum
Thursday, June 28, 2012 4:05 PM
installed a new fuel pressure gauge last night, plumbed directly into the fuel rail. it works, but doesn't seem right. at idle, it's reading ~64psi and when i open it up, it drops to ~60psi. i thought the pressures were supposed to be ~55 and ~50 respectively. i have the ground on the sender going directly to battery ground and the gauge grounded to chassis in the cabin. could this be a voltage offset from the different ground locations, and maybe i should run the sensor ground to the same location as the gauge ground?
Pic - Sending unit location
Pic - Fuel Pressure Gauge reading
Re: Eco Fuel Rail Pressure
Thursday, June 28, 2012 4:25 PM
could just be that its a electronic gauge and wont be as accurate as a mechanical one.
i have a mechanical gauge on my fuel rail, its reads 64 static just like i set it....even verified with 2 other gauges.
Thursday, June 28, 2012 4:48 PM
Cool. Sounds like i'm reading good then. Thank you.
Thursday, July 05, 2012 7:45 AM
i have an 04 but dont recall that location to put a fuel pressure sending unit there...did you 'tap' into the end of the fuel rail or did you have a pre-existing location to screw in that fitting?
04 Cav. 2dr. 5spd. My DD. 'Nuff said.
Thursday, July 05, 2012 8:26 AM
Fuel pressure is almost always listed as "ignition on, engine off"
So basically, key on, let the pump prime, don't start the motor.
That's how I've always seen it anyways.
