Adding a water temp gauge 99 z-24 - Performance Forum
Sunday, July 08, 2012 6:05 PM
I searched and found a few threads, but they didn't have what i was looking for. I'm looking for options to install an electronic gauge (autometer pro comp) using the stock sender (LD9) OR at least the stock location without adding a tee.
So does anybody know what the gauge wants to see for resistance or what the sensor will put out? I know one of the threads someone mentioned a GM 3 wire sensor, or would it be as simple wiring the gauge lead into the sensor wiring?
And if anyone is wondering the gauge in the cluster is not working (reads over 200* all the time) and i would rather not replace the whole cluster. I also know the sensor is correct, it reads 180 ish on the scanner cruising.
Re: Adding a water temp gauge 99 z-24
Monday, July 09, 2012 8:13 PM
If you change your mind about buying a cluster lemme know, I have one for sale.
Tuesday, July 10, 2012 5:53 AM
I guess it might interest me... for the right price... gotta be a 99 manual trans..
Tuesday, July 10, 2012 8:01 AM
In one of the old oil pressure posts people were using a port on the back of the block that was in the water gallery. it was 1/8 npt if I recall correctly. There used to be pictures of it as well.
Tuesday, July 10, 2012 8:23 PM
1/8? Seems pretty small for a temp sender...
Tuesday, July 10, 2012 8:38 PM
I use a GM 3-wire to run my MS-II and factory ECU off of 1 sensor.
Wednesday, July 11, 2012 4:01 AM
Jordan wrote:1/8? Seems pretty small for a temp sender...
You do know that 1/8 NPT isn't 1/8" correct?
Wednesday, July 11, 2012 5:58 AM
SHOoff wrote:I use a GM 3-wire to run my MS-II and factory ECU off of 1 sensor.
Part number? Or what car does it come from?
And yes i know what size 1/8 pipe is.. it just seems small since most senders i do at work are 3/4. But then again thats on tractors.
Tuesday, July 17, 2012 5:14 AM
Most all automotive sensors run off either 1/8 npt or 1/4 npt.
Tuesday, July 17, 2012 8:53 PM
-MD- Enforcer wrote:Most all automotive sensors run off either 1/8 npt or 1/4 npt.
I don't doubt that, but like I said, I work on tractors mostly and everything is a step or two bigger on them.. never had to mess with senders and such on cars, only ever touched the one on my cavy was to swap coolant temp sensors when my water outlet cracked
Wednesday, July 18, 2012 6:13 AM
Order it for a 93 Cavalier w/ 2.2L engine. IIRC
