Ln2 rebuild question? - Performance Forum
Wednesday, August 01, 2012 1:30 PM
IM REBUILDING MY 97 LN2......BY DOING THE ROCKER ARM ROLLER TIP 1.6 AND SBC VALVE SPRINGS WITH P&P HEAD ALSO THE M98 OIL PUMP..AND MAYBE GETTING A STAGE 2 SPEC CAM REGRIND ,THE PISTON SWAP FROM 2200 T0 2.2 FOR HIGH COMPRESSION...WILL IT RUN GOOD WITH THIS SETUP WITHOUT A TUNE??...OR SHOULD I GET A AGJUSTABLE FUEL REGUALTER TO RUN WITHOUT TUNE?????...
Re: Ln2 rebuild question?
Wednesday, August 01, 2012 1:38 PM
Dont think it will run good with those pistons without tune.
Wednesday, August 01, 2012 2:02 PM
First off, you should buy my head, cam, lifters, rockers, pushrods.
Im selling it all.
Let me know if your interested.
Wednesday, August 01, 2012 2:04 PM
two rules of thumb here.... 1) stay away from all capital letters, and 2) if you change the cam, you will need a tune....
an AFPR will not do the job alone, You are going to want to get the fuel trims and the ignition timing set properly.
Saturday, August 04, 2012 7:06 AM
Ok thanks for the info...
