Braided stainless line for the motor... - Performance Forum
Tuesday, September 04, 2012 10:10 AM
Has anyone used any stainless braided line from the water pump to the thermo-stat neck. Would -8an line be large enough? Seems like the stock line measures between -6an and -8an.
I plan on using -6an lines for my external trans cooler to the trans, and bypassing the stock cooler altogether, and -4an lines for my power steering relocation. Seems like a few have used -4an or -6an for the power steering lines.
Any thoughts from anyone?
Re: Braided stainless line for the motor...
Tuesday, September 04, 2012 10:56 AM
I was going to cut my tube off the water pump housing and use -8 to the waterneck. But decided to keep the plastic clip peice for now and run a hose from there to the water neck.
-8 for waterneck line
-6 for PS lines
Tuesday, September 04, 2012 11:16 AM
David, are you just letting the line hang around the back of the motor?
Tuesday, September 04, 2012 11:39 AM
Well I cant remember the size but M2 was going to chop my water neck off if I wanted and thread it for i want to say -12... right now I have stainless braided for all but the 2 main coolant lines... not an LD9, but I dont see any reason why you couldnt use it...
Tuesday, September 04, 2012 12:01 PM
-MD- Enforcer wrote:David, are you just letting the line hang around the back of the motor?
Here's a quick pic of I think Tylers. -8 bung
But a line coming from that and yes loop around the back of the motor to the water neck. I was trying to find a pic of Fetters but he took his pictures off and they aren't available. He had a good pic of how he did his.
Tuesday, September 04, 2012 12:08 PM
Ahh I found it. Brandon old setup and how he ran his lines
Wednesday, September 05, 2012 4:02 AM
Sweet man. Thanks for the picture of Brandon's!
Wednesday, September 05, 2012 5:11 AM
NP
Wednesday, September 05, 2012 7:25 PM
You will need to use -6 for the power steering lines as the adapters for the rack and pump are for -6.
