oil pump gears? ati damper - Performance Forum
Tuesday, February 05, 2013 3:27 AM
I was just wondering if the ati damper will solve the problem of the gears cracking? I know it was the pulley evpanding that xaused them to shatter so would the damper solve that? Since ge damper will help out in other areas....
Re: oil pump gears? ati damper
Tuesday, February 05, 2013 3:54 AM
No, it will not. The gear design is why they crack at high RPM, 2-step use, and hitting the rev limit.
It may help reduce it, but it will not eliminate it.
Tuesday, February 05, 2013 5:34 AM
Just buy the hardened gears...
They are cheaper than the ATI dampener.
Tuesday, February 05, 2013 11:07 AM
Hardened gears went in mine this past year. The ATI damper wont fit without some serious frame modifications. its too big. You also have to clearance the timing cover in order to get the ATI to fit. To me that wasnt worth it and I went back to stock.
Tuesday, February 05, 2013 1:32 PM
Not true Built.
I had one and ran it for a while, the only thing you have to clearance is the oil pump cover... Millerbuilt has it now.
Tuesday, February 05, 2013 8:01 PM
Oil pump gears are more expensive since from what ive seen only 2 places have them smg and gm... building an 11 second car sucks hHa
Tuesday, February 05, 2013 8:56 PM
No ecotecnik
The Ati is usually around 500 bucks
Tuesday, February 05, 2013 9:13 PM
I got my oil pump gears directly from bates engineering.
Tuesday, February 05, 2013 9:52 PM
Jeff reiland sells them for 300 and the gears were 370
Tuesday, February 05, 2013 10:07 PM
Wednesday, February 06, 2013 5:17 AM
jason norwood wrote:Not true Built.
It depends on which version you buy.
Wednesday, February 06, 2013 5:22 PM
i sure do and you spelled MillerBilt wrong lol
RIP Cpl Derek Kerns And Cpl Robby Reyes
24th MEU VMM-261 (REIN) V22 Crewchiefs
11 April 2012 Morocco (African Lion)
Wednesday, February 06, 2013 6:19 PM
Cool, when is it gonna be done??
