oil pump - Performance Forum
oil pump
Saturday, February 23, 2013 9:28 PM
Hello guys
i wish to know what is the physical difference between the standard and the high volume oil pump.
Is there something whrite on the pump itself ?
For a 3.1 1989.
How can i ident. them ?
Do you know the parts numbers ?
Thanks
Al
Re: oil pump
Sunday, February 24, 2013 12:48 PM
you'll probably have a better shot of getting an answer in the Second Generation forum.
Re: oil pump
Tuesday, March 05, 2013 9:57 AM
High volume oil pumps can potentially suck your oil pan dry, during certain events, without adding 2-3quarts of extra volume to the system.
I'm not saying it could happen to you, but a new standard pump is usually enough for even dual bypass oil filter setups and oil-feed turbos and restore proper oil pressure to a tired engine.
1995 Corsica and a bunch of trucks too...
Re: oil pump
Tuesday, March 05, 2013 9:19 PM
Thanks for the tip,
i also wish to know why there is a plastic tube between the drive rod and the body of the oil pump.
The one i have is broken.Is it really nesseseray?
Thanks
Re: oil pump
Thursday, March 07, 2013 7:17 AM
the plastic tube is there to keep the shafts aligned. yes it is necessary.
