hey guys I got a front and rear strut bar brace for my 95 cavalier. Front went on np. The back one is a bit different. It looks like 2 out of the 3 bolts holding the struts have a welded nut to the sheet metal on the top side. My brace is made to be held on two nuts? Is there a way to get these nuts off or do I have to grind it off and use a new nut/bolt?
Thanks,
Kevin
why is the one so far down? did you loosen it? i am unsure on which two your bar is meant to attach to but ive always just put it on top of those and if there was a third mounting one, i used a spacer underneath to make up the difference on the one that has no welded nut.
M45/OS crank/2.4 snout. It's nice to be injected but I love being blown!
yeah its loose. when you sit it ontop what do you use to hold it down
I had a bunch of spare hex nuts laying around when I installed my bar, but any hardware store will have a nut the proper size. I believe its M7x1.25, but I cannot remember exactly since it was a long time ago that I was at the store looking for this size.
"A car just isn't a car without a little blood, sweat, and beers." -- Shadowfire
Thanks didnt really think of just sitting it ontop and adding another nut. Good idea
I added extra nuts and I had to use a washer of six. lol
What style bar you installing? Just a ebay special one
FuzzMASTA9
y ep ebay special, 36$ for front and rear
Yea I use to have them ones back in day, did same thing on rear bar as the others with washers under the one stud to kick it up level with the welded nuts and than used regular nuts on the bolts going upwards from inner wheel well. You will feel a difference even with them bars but for front a personally prefer the convertible front bar since tucks closer to firewall, on my old 98 constantly had to pull off front bar to work on engine with the ebay bar vs vert bar was out of the way, but for price there still nice
FuzzMASTA9
Thanks for the info. This car has been turned into an oval racing car. Its all ready to go this strut bar was the last edition to the car
Cant wait!
Here are a couple pics:
On another note, My wiring is all taken out of the car with the exception of my speedo. It is fully working and used. How can I turn the backlights on for the speedo guages? Can I run power to one of the pins?
on right side of gauges on top is a 2 wire plug i believe with whiite and black wires, if it has it that controls the power to just the backlights
FuzzMASTA9
lol why not just weld a bar across the rear towers? surely with the roll cage its stiff as hell already...
i could have just welded something in, but my welding is not very good. A friend helped me weld in the roll bar. The strut braces were 36$ for two. Tubing would almost cost me that lol
Pete P wrote:on right side of gauges on top is a 2 wire plug i believe with whiite and black wires, if it has it that controls the power to just the backlights
Thanks I will check this when I am at my garage next. I would be very happy
