Well I am still waiting for my head to get back... But I am just about done with the bottom end build. Here are the specs...
Wiseco 8.9: 1 Stnd Bore
Eagle H-Beam rods
Arp fasteners
Clevete main/rod bearings
custom forged crank
Now I am using girdle (mains) ordered from
here.
(http://www.crateenginedepot.com/Ecotec-Main-Girdle-Bolt-11571239-P10519.aspx)
Where I am stuck is the outer crank case bolts. I was told that the LSJ use the same bolts and that
these would work.
(http://www.crateenginedepot.com/Ecotec-LSJ-Main-Girdle-Bolt-11518056-P24001C661.aspx)
Any advice is greatly appreciated.
You drive a cavalier? Why yes... yes I do.
cannot help, never built a LSJ... I know they are right for the L61, need to ask someone that has swapped bottom ends or something......
Thanks for the response Jason.
I should probably clarify... I'm not building an LSJ (head or bottom). I need to know if the LSJ outside girdle case bolts will work on an l61?
Will
these work?
Anyone?
Just reuse them.....
"You can only feed them semen for so long before their legs fall  off."
