Differences between 03 l61 and 06 l61? - Performance Forum
Tuesday, August 13, 2013 4:14 PM
I bought a 0 miles l61 from mongorat on css.net, he says its an 05 or 06. looked for differences between the two and my 03 from the cav, and cant find much. Seen that theres a slight increase in hp and tq. Was wondering why ? Planning on pulling the pistons, and connecting rods to replace them with forged low compression pistons and forged connecting rods, arp head studs and boost it. Will factory valvetrain hold much boost ? Or do i need to upgrade springs, valves, ext. thanks guys !
Re: Differences between 03 l61 and 06 l61?
Tuesday, August 13, 2013 4:36 PM
http://www.j-body.org/forums/read.php?f=2&i=392752&t=392752#392752
This helped! If anyone has more feel free to add!
Tuesday, August 13, 2013 6:58 PM
Main problem....CPS "crank trigger wheels" are completely different. aka reluctor wheels
Oil pan, and mounting points. If you use all accessories from the 03, and swapped over crank shafts it would work.
I'm not 100% on everything since I know enough to be dangerous about ecotec's.
Tuesday, August 13, 2013 7:45 PM
-MD- Enforcer wrote:Main problem....CPS "crank trigger wheels" are completely different. aka reluctor wheels
Yeah i gotta find out how to tell what year the short block is. But he said 05 or 06. Even if its an 06 it may still work because thats the year they changed it but not right at the start of the year.
Tuesday, August 13, 2013 7:48 PM
I plan on using my 03 oil pan, mounts and other necessity's. worse comes to worse i will have to swap my crank nd wheel which isnt bad. I should correct what i said i put a down payment on a 0 miles shortblock and head. No pan, thermo housing, valve cover.
Wednesday, August 14, 2013 3:34 AM
I guarantee if it is an 06 it has the wrong trigger wheel.
Some 05s will also have the wrong trigger wheels....Like 05 cobalts, HHRs, G5s, Saturns, and a few more.
Wednesday, August 14, 2013 6:57 AM
Ok, how can i tell what trigger wheel is on it, ive been looking at the pics of the shortblock and my 03 and dont see a major difference. Any part numbers or markings that would tell what trigger wheel is on the new motor?
Wednesday, August 14, 2013 3:34 PM
If it came out of an 06 it's the wrong wheel heck if it came out of really anything but a J chances are it has the wrong wheel (not sure on the ones that came in Malibus and stuff at the time). Biggest difference will be the pan internals and block should all be standard stuff however except for the wheel again ECOs didn't get VVT till 07 iirc. I'll wait for the bigger ECO experts to chime in
Wednesday, August 14, 2013 4:00 PM
Thanks guys for the info. I have an 03 thats perfect except the head( intake valves bent and touched eachother) so i will get the crank knife edged or something while its out and put it in the new shortblock. Any more info is greatly appreciated.!
Thursday, August 15, 2013 7:16 AM
Here's some good info on the ECO to look over. Did the leg work for you but a lot of this was found here.
L61 ECOtec overview
ECO build guide
GM Family II engine wiki
Thursday, August 15, 2013 11:48 AM
Looked through all that info and couldnt find differences between cobalt l61 and cav l61... Its all good i think i have it figured out thanks alot guys !!
Thursday, August 15, 2013 10:30 PM
-MD- Enforcer wrote:I guarantee if it is an 06 it has the wrong trigger wheel.
Thats not exactly true, this was just went over on a facebook group the other day.
Some '05 Delta L61's 100% had the 6+1 trigger wheels from the factory on them.
James, pull the crank sensor out, and spin the motor around while looking through the hole, if there is only 7 notches (2 really close together) and not 58, then your good to go.
Friday, August 16, 2013 2:10 PM
Thats what i was lookin for thanks newt!
Monday, August 19, 2013 3:09 AM
My 06 HHR didn't have a 6+1 and it was built in Mexico in 05.
