Complete Part out - Mid East Region Forum
Complete Part out
Sunday, December 11, 2016 7:35 AM
Finally doing a part out. I hate to do it but family circumstances trumps all. I am willing to drive up to 25 miles to meet and deliver the bigger items to avoid shipping them. Ill keep checking here for updates. If you need to get a hold of me asap text me 614-774-3273.
I will have more items I will list as I start to remember what I have.
Turbo setup:
GT3071R Garrett ball bearing turbo. 3" 4 bolt exhaust flange and 3" compressor side.
The compressor housing is candy apple purple. 700$
Custom downpipe to match on the passenger side. 150$
log manifold hot temp coated black. 150$
3" custom exhaust 80$
2.5" bar intercooler - 30x8x3 75$
2.25" polished hot side charge pipes
2.5" cold side charge pipes
Tial 44mm MV-R purple waste gate with springs for 17lbs of boost in it. 350$
I can do a package deal for the turbo kit.
Engine: Dynoed at 330 Hp and 303TQ. Will hold a lot more
Ross machining sheet metal polished intake manifold 550$(Sale Pending)
LS1 stock 80mm TB
Make me a reasonable offer on the whole engine itself. I will not break the engine down to take parts off. Engine goes as a WHOLE.
Ported and polished head
3 angle valve job
deck shaved
SS valves
bronze valve guides
ARP head studs
ARP Main studs
Cometic .030 NA head gasket
GM 2.4 Keepers
2.3 springs
2.3 Titanium hybrid retainers
2.3 lifters
2.3 HO Intake cam modified for PS
2.3 HO Exhaust cam
Block deck shaved
block bored .020
blue printed and balanced
crank polished and lightened
2.3L oil pump conversion
Wiseco 9:1 pistons
Eagle H-beam connecting rods
ARP main bolts
Clevite 77 rod and main bearings
TurboTechRacing Powder coated black upper solid mount
Carcustoms lower mount
MDLD9 lightened crank and alt pulley
Rksport oil cooler
Polished 160 amp alternator
160 degree thermostat
1100cc ev14 FIC high impedance injectors 100$ (sale pending)
Aeromotive AFPR 100$
Racetronix fuel pump harness 80$ (sale pending)
2002 Getrag rebuilt 5 speed trans with Tream Green LSD installed. 250$
Suspension:
TEIN basic coilovers with 2" lower springs in the rear. 450$
Baer 13" front brake kit 600$
Neon rear disk conversion(NOT installed) 220$ shipped
17Ē Konig black rims 200 miles on them
Tires have maybe 200 miles on them 800$
F-Body 2.5" ARP wheel studs
Rksport front upper strut bar
Rksport Front lower subframe bar
Vibrant rear upper strut bar 20$
Addco rear sway bar 40$
Addco front sway bar 40$
Poly urethane control arm bushings offer.
Addco Polyurathane Swaybar Endlink Bushings 20$
VIS CF Turbosport hood 300$
Carbon by design carbon fiber trunk 250$
Import fighter front 200$
Import fighter replica fiberglass sides 20$
03+ LSS rear bumper 40$
Toyota 95-99 tail lights 175$
95-99 crystal clear headlights 50$
black corners 10$
Aem wideband 100$
Z series black Boost gauge 15$
Z series black Oil pressure gauge 15$
140 MPH black cat custom cluster with red LEDís 150$
black NRG steering wheel 80$
momo hub 60$
Re: Complete Part out
Friday, December 30, 2016 11:40 AM
I feel like I'm stalking you at this point....
Saturday, December 31, 2016 8:56 AM
Tuesday, January 09, 2018 12:53 PM
do you have stock suspension? i need at least the fronts
