Help with rear window removal on 84 Cav Convertible - First Generation Forum
Tuesday, April 26, 2011 6:47 PM
Hi,
Need help removing right rear window and regulator on 1984 Cav Convert. I just have the interior trim pulled back as I have stripped the torx head bolt for the top half of rear seat. I have the top bolts removed and the assembly moving around but I cannot seem to locate the bottom bolts. I just want to remove this to push out a dent in rear quarter . Is it easier just use a dent puller?
Any help appreciated! ......John
Re: Help with rear window removal on 84 Cav Convertible
Wednesday, April 27, 2011 6:44 PM
Got it out today. Just needed to remove the factory goop covering the lower nut and with a little elbow grease the window and regulator came right out. Now I just need to be patient and tap out the dent.
