Recognize Daryl Scott - First Generation Forum
Saturday, May 14, 2005 7:40 AM
Like the title states. I just wanted to recognize Daryl Scott for the strut bar he sold me. It was shipped super quick and packed excellent.
Re: Recognize Daryl Scott
Saturday, May 14, 2005 7:31 PM
Thanks Tom.
-Daryl Scott
<A HREF="http://www.geocities.com/doctorsvt/cav.html">*86 Cavalier RS convertible
<A HREF="http://www.geocities.com/doctorsvt/scx.html">*92 Olds Achieva SCX- SOLD...sort of.
<A HREF="http://www.geocities.com/doctorsvt/cobra.html">*98 Mustang SVT Cobra #503</A>
<A HREF="http://www.geocities.com/doctorsvt/sarahcav.html">*01 Cavalier LS Sedan</A>
<A HREF="http://www.geocities.com/doctorsvt/cav.html"><img src="http://www.j-body.org/registry/monkeyspunk79/thumbnail_suncav.JPG"></A> <A HREF="http://www.geocities.com/doctorsvt/scx.html"><img src="http://www.j-body.org/registry/monkeyspunk79/thumbnail_SCX%20side.JPG"> </A> <A HREF="http://www.geocities.com/doctorsvt/scx.html">
<A HREF="http://www.geocities.com/doctorsvt">Top Down, Tank Full, Pockets Empty
Saturday, May 14, 2005 7:40 PM
Did you put it on yet?
-Daryl Scott
Sunday, May 15, 2005 8:32 AM
Not yet. I am still finishing up the front end. I am waiting on a z24 front sway bar. However, I have test fit the bar and it seems good. Since this car is a V6 and came originally without a tie-bar, I needed to move the harness down off the blower motor for it to sit properly. I should post some pics of the suspension rebuild when I'm done.
Tom
Sunday, May 15, 2005 10:31 AM
Yeah, I had to move the blower motor harness, etc off the top as well. Good luck with your rebuild. I'm due for that soon. Did you order individual parts, etc from a parts store or did you get a kit from PST or somewhere?
-Daryl Scott
Monday, May 16, 2005 8:43 AM
I went with pretty much stock parts and a few minor enhancements. I stayed with rubber for the bushings as opposed to putting in poly. I replaced the following:
Front:
KYB GR-2's struts with KYB strut mounts, gabriel upper spring seats, Eiback springs, and new gm lower spring isolators.
New GM tie rod ends
New GM A-arms which included the bushings and ball-joints
New GM sway bar bushings and end links. I am waiting on the arrival of a 30 mm front Z24 sway bar to finish up the front. The car had a 24 mm bar in it.
A new GM lower tie bar, and your upper strut bar.
New brake calipers, rotors, and rubber lines.
New power streeing pump, cooling line, and pump inlet & outlet lines. I also changed the belt while I was at it.
Rear - not installed yet:
KYB GR-2 shocks and KYB mounts & Eiback springs
1987 Z24 rear sway bar (not sure of the size - matched one to the front)
New rear brakes - including drums, shoes, spring kit, wheel cylinders, and lines.
Tom
Monday, May 16, 2005 4:35 PM
Sounds great, Tom. Looks like you'll have a nice solid car on your hands once she's done. Nothing like taking the slack out of the steering and brake systems.
-Daryl Scott
