speakers in dashboard - First Generation Forum
Wednesday, June 01, 2005 12:23 PM
I'm just curious as to how hard it is to replace the speakers in the dashboard. I have gathered that they are 3.5" but dunno about putting them in. Do you only have to take off the grill and then you have access? How about getting the screws out? On the passenger side things are pretty cramped!
Right now I have stock speakers in it which my stereo quickly blew. Infinity 6x9's in the back.
Thanks, Dayton
'85 Cavalier 4 door
2.0
Re: speakers in dashboard
Wednesday, June 01, 2005 7:09 PM
take a thing screw driver and pop the covers off, then you will need a metric socket set...the screws schouldne be too tight its only plastic just try to screw then out by hand, if not get a small ratchet and take them out, then just pull the speaker up and disconnect the wires, the end
*Nic
Wednesday, June 01, 2005 7:13 PM
I redid all my audio last summer and those in the front were pretty easy but I ran all new speaker wiring front and rear oh the fun,factory speaker wiring sucks plus being so old it had static u could here from the car running.I bought JLs for my front and boston acoustics in the rear.
Thursday, June 02, 2005 4:56 AM
Get a 1/4 drive ratchet set to take up less room.
Saturday, July 09, 2005 8:20 PM
I used an offset (z shaped) screw driver. It was a piece of cake.
Sunday, July 10, 2005 2:25 PM
get some infinty 3.5's in the front they sound great i have them in my firenza... i just re did all my speakers and it was a breeze in the front. i didn't realize how easy it was. i probley do need new wire cause it's still static. how hard was getting new wires installed?
<BR><IMG SRC="http://registry.gmenthusiast.com/images/ylime555/sig.jpg">
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/mnjbo2.gif"><IMG SRC="http://registry.gmenthusiast.com/images/ylime555/ylime.gif"><IMG SRC="http://registry.gmenthusiast.com/images/neo32843/mnjbo2.gif">
Sunday, July 10, 2005 7:26 PM
installing new speaker wiring was pretty easy in the front ,compared to the rear.U just have to route it down towards ur head unit and did remove a panel or two so I could see where I wanted it to go.The rear was timely due to I routed it back thru the exact channels all the way and there are two plastic holders that hold some electrical wiring which the original wires went so, I did it just so to b perfect .Took me a couple of hours cause I did have to remove the back seat and remove the plastic trim along the door in order to get at the channels I described.Have fun I did.
