just bought - First Generation Forum
just bought
Tuesday, February 21, 2006 7:55 PM
ok I just bought an 87 sunbird gt with TBI Im planning on swaping it to MPFI and rebuilding it from the ground up with forged pistons and everything.Im going to strip the car and make it light as posssible and run it on a drag strip. The guy doing all my machine work told me that the engine will be bullet proof. I believe this guy because all he does is build race cars so I have no reason to doubt him. Any ways hes going to build my motor for cheap real cheap so hes going to find a cam that will work and all that good stuff and he guarantees me 400 hp and he says it could also run a 100 shot of nos but he alo says that if it didnt dyno 400 hp or blew up hed buy me any car I wanted. so whatcha think.any questions.
Re: just bought
Tuesday, February 21, 2006 10:43 PM
400hp, not possible with an 8 valve head, let alone n/a. a turbo motor is possible to hit 350hp, but thats about as much as the cyl head can support, it just cant flow enough air for anything more. if you run a 16 valve head, it may be possible.
if your gonna build a motor up for boost, just start out with a 2.0l turbo motor. it is a lot different and stronger.
Re: just bought
Wednesday, February 22, 2006 3:24 PM
thats what we are doing. boost and yes an 8 valve head he buils them all the time so he knows what hes talking about
Re: just bought
Wednesday, February 22, 2006 6:56 PM
ok well good luck with 400hp, but ats already been proven that the stock head, even ported to the max, cant flow enough air for more than 350hp
Re: just bought
Thursday, February 23, 2006 6:45 PM
I'm curious where and by whom that was proven. I'd like to see the flow numbers too.
I'm not saying you're wrong I'm just saying I've never heard that anywhere before so I'd love to see any documentation on it.
Tony
Tony
1987 Sunbird GT turbo convert
Ported intake, Fiero 53 MM TB, 52 lb inj, ported and flowed head, tube header, Mitsu TD06, ARP rod
bolts/head studs, adj cam sprocket, 4" x 12" x 31" FMIC, Paxton AFPR, modified 125 trans/LSD
unit/3.42's, custom chip tuning, Alky Control Methanol injection
13.61 ET at 101.44 mph, 262 WHP/350WTQ
2009 Pontiac Solstice GXP roadster, 2.0 turbo w/GMPP exh, CAI and turbo upgrade, 290 hp/325 ft lbs
1969 Olds 442 convert
400 Eng, 200-4R trans, 3.73 posi, power everything, OAI
Re: just bought
Thursday, February 23, 2006 8:31 PM
head over to www.lt3engine.tk , thats the side dedicated to the 2.0 turbo.
Re: just bought
Thursday, February 23, 2006 8:52 PM
No kiddin', I go there all the time but I don't recall the post you're quoting. I remember someone saying a few years back that some engine builder found that at the 350 hp level the cooling system couldn't keep up. The only head flow numbers I ever saw were the ones I posted a while ago. Am I missing something on there?
Tony
Tony
Re: just bought
Tuesday, March 21, 2006 11:58 PM
so what ever came of this, aaron new car yet? or is there a 400hp sunbird rollin around
1st 1st gen on air.....
Re: just bought
Wednesday, March 22, 2006 11:45 AM
havent had time to break it down yet. but its coming
