need help with 3.1 asap!!!!!! - Second Generation Forum
Saturday, April 16, 2005 11:51 AM
alrighty here it is 92 z24 3.1 new tune up including o2 no cat (clogged as hell) so its straight piped new aic checked the ignition controle mod and its good new air intake temp sensor still wont idel and acts like its running ritch and smells like it. checked the fuel pump reg and its fine
ne ideas on what this could be
oh and when you first start it up in the morn it runs fine but as soon as it gets warm it goes crazy
someone said that the oil sensor could be bad causing the fuel pump to shut off??????
Re: need help with 3.1 asap!!!!!!
Saturday, April 16, 2005 12:24 PM
have u checked your injectors?, sometimes even running some fuel injector cleaner will temporarily fix 'em
<img src="http://www.geocities.com/fudd_22602/elmer-shoot.gif"> Old school Js rock
Saturday, April 16, 2005 1:11 PM
it wont run long enough to us injector cleaner is theyr another way to clean them
Saturday, April 16, 2005 1:34 PM
sounds like O2 sensor
Saturday, April 16, 2005 4:58 PM
mitchell dingus wrote:it wont run long enough to us injector cleaner is theyr another way to clean them
I've never done it but some have said that soaking them in gas works, I have no idea though... Its a pain getting them off though, I would check your sensors before I went that route. I just named the easiest possible fix
Wednesday, April 20, 2005 7:39 AM
also check your map sensor located behind the intake plenum on teh left side when ur facind the engine
Thursday, April 21, 2005 8:27 PM
soak your injectors in some kerosene. it works trust me
People say that what doesn't kill you in this life
will make you stronger. I'm not sure if that is true
or not, but i do know one thing-You have to learn from
it and it has to make you better.......it has to.......
Friday, April 22, 2005 5:45 PM
got the prob fixed
it was the injectors (they were warn internaly)
but thanx for all the help
