Thermostat - Second Generation Forum
Thermostat
Wednesday, May 18, 2005 8:48 AM
anyone how how to replace the thermostat on a 94?
Re: Thermostat
Wednesday, May 18, 2005 10:57 AM
ummm I've never worked on a 2.2 but I would assume they're the same as the other 2nd gens, it just sits in the radiator cap housing, take off the cap and pull it out.
<img src="http://www.geocities.com/fudd_22602/elmer-shoot.gif"> Old school Js rock
Re: Thermostat
Wednesday, May 18, 2005 12:41 PM
lol a '94 what? 2.0/2.2/3.1
Re: Thermostat
Wednesday, May 18, 2005 12:55 PM
if its a 2.2
where your upper radiator hose connects to the engine remove that housing (3 bolts) and its right there.
Re: Thermostat
Wednesday, May 18, 2005 5:20 PM
um.. its the square boxy four door one... its not my car so i really have no idea haha anyone have ideas? i founda how to on autozone.com but im not sure if its correct, im assuming its not the the radiator part because i got a gasket with it
Re: Thermostat
Wednesday, May 18, 2005 8:30 PM
dude if you don't even know what kind of engine you have the web probably isn't the place to get help. Is it a four cylinder or a V6? If its in the housing on the block (from what I understand on the 2.2) it wouldn't be a bad idea to replace the gasket on the housing when you pull it off
Re: Thermostat
Thursday, May 19, 2005 1:03 PM
its a 4 banger so its gota be the 2.2 but i am confused because if you take a look at this
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0e/ff/a9/0900823d800effa9.jsp
which is from the autozone website it says the thermostat sits under the manifold.. took it all apart today.... no thermostat...
Re: Thermostat
Saturday, May 21, 2005 12:57 AM
According to that information, that would be where the lower rad hose connects to the water pump. If there's no thermostat there, then 1 of 2 things:
1) If it isn't where its supposed to be, where the upper rad hose connects to the engine, there should be something that looks like a thermostat housing. Try there. --or--
2) Somebody along the way forgot to put the thermostat back in before you became fortunate enough to try to find it.
Re: Thermostat
Saturday, May 21, 2005 5:36 AM
Hi Dane
I think your thermostat is the one shown in 1987-91 2.2's. It is on the 1993 2.2 four doors I work on and it may still be in the same place in the 94's
Alont
Re: Thermostat
Saturday, May 21, 2005 9:11 AM
Thats it circled in red, bolted onto the head.
http://cavalierman93.googlepages.com/
