OVERHEATING - Second Generation Forum
OVERHEATING
Friday, May 20, 2005 10:23 AM
the 1994 2.2 is overheating, changed the thermostat.. the water pump seems to be circulating... can anyone help me out?
Re: OVERHEATING
Friday, May 20, 2005 12:51 PM
check your coolant level? Is your fan running? Does it still have the original radiator and lines?
<img src="http://www.geocities.com/fudd_22602/elmer-shoot.gif"> Old school Js rock
Re: OVERHEATING
Friday, May 20, 2005 12:54 PM
head gaskit....
chris
'02 Z-24 Supercharged
Re: OVERHEATING
Friday, May 20, 2005 1:00 PM
um... newer radiator, coolant is full and fan turns on, there is no coolant mixed with the gas...
Re: OVERHEATING
Sunday, May 22, 2005 6:58 AM
with the gas? look for it in the oil, what i was geting at though was this, if you have a cracked head gaskit, pressherised air from the combustion chamber can airerate( sp?) the coolent in the head, thus causing it to over heat.
chris
Re: OVERHEATING
Sunday, May 22, 2005 12:33 PM
yah i meant the oil, no coolant in the oil
Re: OVERHEATING
Sunday, May 22, 2005 1:16 PM
wertwe qj wrote:yah i meant the oil, no coolant in the oil
It could still be bad, pull the 2 right hand plugs and see if they are white.
Re: OVERHEATING
Sunday, May 22, 2005 4:50 PM
checked em.. not white...
Re: OVERHEATING
Monday, May 23, 2005 11:37 AM
.. WHAT IM SAYING.
A, the head gaskint is cracked and PRESSHER from the cumbustion chamber is entering the waterjackits in the head, casuing the coolent to boil, this casuing coolent not to take heat away from the head.
or
B. the head is cracked, AGANE causing PRESSHER to enter the
water jackit and boling the coolent.
ither way you can ither do a leak down test to see if this is the case, or pressherise the coolent system to see if you have a leak anywere.
chris
