turbo specs? - Second Generation Forum
turbo specs?
Tuesday, May 17, 2005 5:38 PM
Anyone know the specs for the factory turbo on the sunbirds?
I found a cheap t2 that is perfect for what I want but I just wanted to compare to what I have now, I know its bigger but I just want to know how much bigger.
Re: turbo specs?
Tuesday, May 17, 2005 5:45 PM
Also, I'm making a new exhaust manifold for it cause I hear the factory one is pretty restrictive and mine is cracked, and I hear thats a common thing as well so I've decided to make one from scratch and I was just wondering what would be a good size of pipe to use for it, I want to keep it small enough to keep up the velocity, and I've though of a good design thats a lot less restrictive than stock. I was thinking of going with 1" inside diameter turbing but That might be too big, and what thickness of piping should I use so it can withstand the heat? and I'm guessing steel tubing would be best, right? I'm no enginer so I dont know these things, lol
and help comments apreciated, thanks
Re: turbo specs?
Thursday, May 19, 2005 2:14 PM
Someone has to know........
Re: turbo specs?
Tuesday, May 24, 2005 3:57 PM
its a garett t25 look up the specs from there....
Re: turbo specs?
Tuesday, May 24, 2005 8:20 PM
No idea on the actual specs but I thought the T2 is smaller than the T25.. I have a T2 on the bird now that I got dirt cheap but the original T25 is definitely a bigger housing at least. The T2 came on the 1.8 turbo birds IIRC.
<img src="http://www.geocities.com/fudd_22602/elmer-shoot.gif"> Old school Js rock
Re: turbo specs?
Tuesday, May 24, 2005 10:07 PM
t2 and t25 is just the style of turbo, its not the size. case and point: the 2.0l sunbird uses a t25 turbo, and so does the 89/90 turbo grand prix 3.1l, however, the tgp turbo is larger.
