Anybody know how to replace the fuel sending unit in mt 89 z242.lt
Cavyguy08
Unfortunately u have to drop the fuel tank which has two straps holding it and the filler neck and fuel line and electrical plug harness going to it.What I did when I replaced mine was back it up on some car ramps disconnect the batt,and start to remove the stuff.It took me 3 hrs total to do the job and that includes clean up.Now a recommendation is to use liquid wrench or bp blaster on the fuel tank straps that hold it in a day or two b4 on the nuts that hold it being it's never been removed and it will speed the removal of the tank minus using channel lock pliers,flat head screw drvrs to get the fuel hoses loose and clamps holding the hoses.It's pretty simple to do just set aside the more time than necess to do it if u run into issues along the way .
