Forum specific to the 1988 to 1994 J-cars.
First of all (english is not my own language)
I have a 2000 Daewoo Lanos but i swap a LT3 engine in with the 8 valves head!
I begin the project to swap a 16 valves (Daewoo Nubira) head on my LT3 turbo engine...
If someone want to do this, you need almost a complete Nubira engine to make the conversion!
You need the head
The water pump are not the same (not the same number of theet on the pulley) and the T belt gear on the crank and idlers pulley and tensioners+ the timing belt cover...
After that you also need to notch the pistons (LT3 turbo pistons) to allow the space for valves clearance...
BUT i still have a problem...
I want to keep my 749 ECU but i can't put a distributor on the 16 valves head...
How can i have my signal for injection and fire (without distributor) and keep my 749 ECU???
I can use the nubira block (with the hole for the crank sensor) and a cam sensor but how i can convert the signal for my computer ( i see a box from MSD, but the box is for 24 tooth pulley (corvette)
I need help if someone have idea ...
Isn't the LT3 engine a 350 v8? IF so you might want to search for a v8 forum.
NO the engine came from a 89 Sunbird TURBO!
2.0 liters turbo vin (M)...
Robert, I answered your question in the performance forum.
-->Slow
