2.0 Turbo Question - Second Generation Forum
2.0 Turbo Question
Tuesday, August 12, 2008 12:20 AM
Just wondering what turbo came stock on the 2.0L Turbo Sunbirds? and does anyone have any specs on the turbo itself?
_______________________
** Flat Broke Racing Inc.**
Re: 2.0 Turbo Question
Tuesday, August 12, 2008 3:06 PM
Justin...
My '89 has the Garrett 2.5....
Hope this helps,
Moe Whittemore
Monday, August 18, 2008 9:12 PM
Not really, i'm trying to figure out if they are a T25 or a T28 turbo and what the waste gate was set to factory. I'm doing alittle bit of a 'in your face low budget build' on a 300,000km stock 3.1L to kick a certain SRT4's ass around here (i know i know, there will be alot of people hating on me saying it cannot be done) But i'm a mad man on a mission like i have been in the past and the present to prove money isnt everything
Tuesday, August 19, 2008 5:54 PM
It was a T25 with .48/.48 A/R and the computer regulated the wastegate to 8 or 9 psi. A teeny tiny turbo.
Tony
1987 Sunbird GT turbo convert
Ported intake, Fiero 53 MM TB, 52 lb inj, ported and flowed head, tube header, Mitsu TD06, ARP rod
bolts/head studs, adj cam sprocket, 4" x 12" x 31" FMIC, Paxton AFPR, modified 125 trans/LSD
unit/3.42's, custom chip tuning, Alky Control Methanol injection
13.61 ET at 101.44 mph, 262 WHP/350WTQ
2009 Pontiac Solstice GXP roadster, 2.0 turbo w/GMPP exh, CAI and turbo upgrade, 290 hp/325 ft lbs
1969 Olds 442 convert
400 Eng, 200-4R trans, 3.73 posi, power everything, OAI
Tuesday, August 19, 2008 11:13 PM
I knew it was small. now this sucks, i've got one turbo from a 80's 300ZX, and one from an 88sunbird 2.0 turbo... they dont match up.. Anyone want to buy a couple good turbos? I think this project is heading in the direction of one large T3 frame or one small t4 frame Ebay turbo
I'm not calling this the 'Grenade' project for the @!#$ of it
Tuesday, April 28, 2009 7:35 PM
I dont think the turbo was computer regulated. There are no electrical connectors to the turbo, just a manifold vacuum line. if you just plug the line and throw a blow off valve on it that would be the easiest way to regulate the turbo boost setting.
Sunday, May 03, 2009 10:23 AM
follow the vacuum line up from the wastegate, behind the valve cover there's a electronic regulator. how is a blow off valve going to regulate boost setting?
Wednesday, May 27, 2009 9:36 AM
sorry. meant manual boost controller. match it up with external wastegate if you have the means to do it.
Friday, May 29, 2009 11:41 AM
Sunbird turbo uses ecm controlled bleed valve on wastegate signal line.
-->Slow
